blackhawkxx
Posts posted by blackhawkxx
  1. A little bit less on the air gap can help with a too light spring but won't get the job done in the opposite case.
    So me being 225 lbs. with stock springs could reduce the air gap to help my front end?
  2. All I know for sure is that I still remember the days of breaker points/coil ignition systems, leaded gasoline, and all the PITA changing/cleaning of plugs every 2000 miles or so, and resetting the timing and points gaps, and I don't miss a bit of it. With modern electronic ignitions, plug gap is certainly less critical, and if the plug gap is close, I wouldn't mess with it.
    True but I also remember buying a brand new car for $5,000.
  3. I frequent a pleasant outdoor dinging restaurant over there and the frowns on the faces of the patrons (can you say rich and influential) as another herd of flatulant bikes go by and stop all conversation has to be seen to be believed.
    Why are bikes not treated like cars when it comes to noise? If run around with a big hole in your car's muffler, you will get a ticket. I often wonder that when a hardly comes past the house shaking the picture on my wall.
  4. I have modified a set of Yoshi's for my bike
    So, just how do they come apart? Can you just take the four screws from the end of the can and the tailpiece come off or do you have to take all of the screws out and the cover slides off? If you take the cover off, is it hard to get back on with the packing and all?
  5. I like the Hondas because there is a guy on Ebay that sells em for 5 for $15 + $4 shipping
    Yea, let us know. Both of my bike uses the same filter and that would be alot cheaper. Just warn him, he might get swamped.
  6. 1. How often should the chain need adjusting, I did mine 2 weeks ago and after about 300 miles it needs done again
    Seems to me that there was quite a thread about after tighting the jam nuts on the chain adjusters, that if you didn't screw in or out (can't seem to remember which) the adjusters themselves, that the chain adjustment would change. Clear as mud, I know. Maybe Pete in Pa could shed of light on this.
  7. I have the same problem. I dropped the rear 1" with a lowering link and slipped the forks in the tubes about 1.25" - 1.5".
    I have done this but only a inch in front. I have very little trouble with things dragging. On some bumps while leaned over it might drag but I have stock front springs. With firmer springs, I think it would be OK. And I am not a light weight.
