FlaminWarrior
Everything posted by FlaminWarrior
  1. YES....just do it, I'm running a 16T just for fun tried it out and it's gr8, cheap mod too!! If you dont like it change it back...
  2. here is the gear Pure street racing at the drag strip, street rego and modified sports bikes. Weight is an issue, but that aint gonna change!! 2002 PCIII K&N 16T front Stock otherwise... 60' 1.8s-1.9s
  3. FlaminWarrior
    NOS
    After dabbling in the drags and being consistantly beaten by those busa boys I'm considering the NOS route, any comments would be appreciated. I'm running 10.8 - 11.0 per 1/4 at the moment, and if beaten its in the last 33'.... most dissapointing!!!! I have access to NX express system has any one had any experience in this system, recommendations..??..?? cheers blu
  4. Is there a wiring diag I can get of someone..??..??
  5. Ok so I have wired white green stripe in and grey out. left green off and sealed so it dont earth.....Indicators work a treat, parking lights A OK ....very happy no blown fuses.... BUT the brake light doesnt come on..??..?? WTF ..??..?? :icon_wall:
  6. Get the center stand stop J does here if he still has some as its a pearler....
  7. Got the clear alternatives rear intergrated light... looks the goods, but I want to install a variable flasher unit into the OEM wires.... 2002 model..... I have cut out the OEM one as the variable one has three pins positioned different than OEM.... only one I could get.... problem is I dont know whick wire to solder onto which pin.... there is white with green stripe...(power) and green and grey.... which one goes where....?? the variable flasher unit's pin arrangement is so..... ..........+ ..........+ ..........+ +....................+ +....................+ +....................+ Any help would be appreciated, clear alternatives have not been helpful, and checking out their web site reveals lots of info including photos for every bike except the honda's..... so Im in the dark.!! I must of wired it in wrong as I keep blowing fuses..... :icon_wall:
  8. :shock: watching with interest.... hey crow... :wink:
  9. plug and play for the brake lights and the running light but there are 4 yellow wires that are the indicator wires that need to be connected to power, this is where I need the help.... :roll:
  10. Not real cear on the turn signal wires, 4 yellow ones, do I just splice them together then splice that into the positive wires for the appropriate side turn signal wire..?? :?
  11. :shock: So they do one for the 2002 bird.... awsome!! 8)
  12. FlaminWarrior
    FORKS
    Do a search on here.... http://www.superblackbird.co.uk/ ...Pete has them as a conversion set, JAWS prob does too.... :wink:
