Warchild, as someone who has rebuilt somewhere in the order of 30-40 forks, let me tell you that you're being fed a some pretty big amount of bullshit there. Unless you are pulling apart Ohlins forks, you don't need any special tools whatsoever. Everything you can get at your local sears. That photo - 90% of the parts are the washers in the shimstacks. Also, you don't seem to know what you're looking at with the second picture. Look at the size of the holes in the ohlins compared to the showa. The holes are at least double the diameter, which means 4 times the amount of fluid travelling through them at any one time. When you hit a sharp bump, that makes a huge difference to the front of the bike.
When he's saying the showa valves are Ok, he's talking for race bikes on a race track where you don't have to deal with large bumps like street riding. In fact, I think he's talking crap about them being 'as good as' anything else - and so does every other suspension expert (got look at the archives of the wera boards for a discusion in this. The thread was about 2 months ago).
For street riding, on street bikes, what you want is the biggest hole size you can get in the valves. This allows a lot of oil to flow as fast as possible in order to deal with big shocks that are typical of road riding (potholes, tar snakes, concrete separators on slab etc). Opening the holes then means you control the damping rates at all points using the shimstack. When you go to a race track, this is not the ideal setup because flowing too much oil will put pressure on the shimstack causing the shims to bend, which then changes the damping characteristics. So race valves use smaller holes to control the oil.
The other reason that he's talking crap is that in suspension - particularly race suspension, you want to run as thin an oil as possible. Heating causes the oil to thin, and the thicker the oil to start with, the more difference that makes. As the oil changes viscosity, the damping characteristics change. So the idea is to go really lightweight oil to avoid this as much as possible and then control the damping with the valves and shimstacks. Typically you aim to use 5W oil in the forks and 5-7W in the shock (although some will use 10W). Standard, all Honda forks come with ATF in them, which is about 8W.
And, just to let you know I'm not just talking out my arse here, when I was working on my VTR forks I first just changed the springs and played with the oile weights and viscosity. Since I couldn't get it right, I then started tweaking the shimstacks. That helped a bit but not huge amounts. Really sharp bumps still screwed the handling up. Finally I put the ST valves in and that made a huge difference. The freer flowing ports is what really makes a difference. I've been through every state of tune you can do to forks on a single bike and so I know the exact effects of each modification. If you don't believe me, jump straight from your bike onto someone that has had the RT valve treatment done to it (or onto mine if you're ever up this way) and you will notice a big difference in handling.
