I did my 97 it was a lot of work but well worth it the end result was great.I'd it again will be alot easyier because I have a Lift that I bought from Harbor Frieght that is worth is weight in Gold as far as I use use a gel striper from HomeDepot because i work there it made by KleenStrip KS-3Preimium Striper and masking tape cheap 1" paint brush and small Wire Brushes then your sand paper started off with 400 grit wet sand ended up with like 1000 to 1500 final it came out sharp love the look so mush I will do it to the 03 and it will not be as hard with the lift push it on to it and jack it up to perfect hight. But alot or work to maintain prob should clear coat it after. I didn't. just a thought.
