The Krypt Keeper
  1. How many miles you got on your bird? I am at 9k miles and just also replaced my sparkplugs. Wasn't much of the irridium there to spark. I noticed here for the past 1500 miles she would crank over for a second or two before firing to life. Changed plugs and soon as my finger hit the buttom she roared to life :wink: Expensive little bastards at $8 a plug
  2. Do they have them listed seperately? Someone posted a thread here talking about the ( tire everyone went and looked to see if they had it or not :roll: Why? Cause no one knew they were making two different tires. When I ordered my tires I was not asked regular, (, or even if I wanna super size it for an extra $.75
  3. If they are going to be so many different tires then they all should be listed different.. At first I loved my 45/46's now I am thinking about how much of a joke Avon really is of a tire company.. Tires are a very important part of a bike. You put your life in the hands of your tires everytime you ride. Don't make 50 fucking options for a tire... sticky wear faster, less sticky wear longer how difficult is that.. All tires should have a standard rating for 200 mph and all the speed rated shit will be no more. Unless you need special applications for your Y2K or jet bike :roll:
  4. Seems I am not the only one with this problem.. just saw this on another site he rides a ST 1100 "@ 45mph +/-4, my front end shakes/wobbles pretty bad because i feel the wobble at near full lean i am not comfortable shredding my new Avons above or below 45 the ride is smooth as usual. the front tire is machine spin-balanced perfectly. i have not checked the alignment on the rear. what could be causing the problem? could it be the unchecked rear? bad steering head bearing? do i need a fork brace? what might it cost? any advice? i need to be informed in case i can't fix it myself ..."
  5. I know we were pulling onto the interstate one time I had 3 bars left.. at the average speed I lost them 3 and had it flashing within 30 miles :shock: Then again at the speed we were going I could have ran out of gas and pulled the clutch in to coast to any gas station with in a 5 miles or so We were late and in a hurry didn't know if running out of gas or getting popped had me more worried :twisted:
  6. This past weekend I was in the moutains and she started flashing.. I rode about 35 unpleasent miles with her flashing.. I was even holding in the clutch when going down hill to just let the bike idle and have gravity help me along.. :shock: I was so releaved when i pulled into a gas station.. think I still put in 5.96 gallons... still had some left, but didn't hear anything splashing around when I shook the bike at the station... :???: Suppose to have a 6.34 gallon tank.... too close for me anyways..
  7. Might go ahead and go that route then, swap out the fronts and just buy me a Avon 50 when I finish burning up my rear... at the rate I am going to the mountians it shouldn't take too much longer
  8. Checked the rotors also when did the run out on the tire.. plus my brakes feel great up front, no pulsing or anything.. The forks are sitting in the tubes clamped tight never been moved. No rear shock upgrade or changes yet.. might change rear suspension soon if I can convince the wife I need to :wink: I did manage to finally get ahold of Avon today, Said they will replace it no problem. But he was trying to get me to replace the front 45 st with a 49 :???: Other than the shape being different more pointy (quicker turn in) made of softer rubber (quicker wear) anyone think this is a dumb idea to miss match tire sets like this :?:
  9. I had my Oxford bags on the back of the bike with maybe 10 - 15 lbs worth of crap. Wheel weights still on.. Just bothers me knowing I was busting ass up and down one mountain trying to break in my knee pucks and the bike felt great.. couple hundred miles later shes shaking like a crack head in need of a fix :evil:
  10. Will do that again.. I did that last time when I first have the balance problem.. :sad: If this don't work I am going to contact Avon... will they give me any crap for running it at 36 psi? Or should I just tell them I had it at what they recommended
  11. damn northman I speak of you and you post faster than I can even hit the reply button... There were a few little bumps I might have hit but nothing major..
  12. Damn really?? I know Northman is running that pressure and a couple others are also.. Might try some more air in the front and see what she does..
  13. Did my ride of the Blue Ridge Parkway this weekend. Rode 750 miles total. But at almost half way I started to notice my front end shaking when going into the corners. :shock: I wasn't really pushing it too hard. I was nearly riding my rear tire to edge earlier in the ride but then she started shaking and would cause me to start backing out of the throttle. I got probably 1500 miles on my Avons 45/46's running 36F and 38R psi. I had some head shake when I first got them put on cause they were balanced wrong. I had them redone and it went away. But now its back, and causing the bars to shake. Even when going straight they shake back and forth. The tires aren't cupped, I am going to try checking my head bearings tomorrow and see. Anyone else got this or got any other suggestions to check
  14. Yeah me and my buddy would play different tunes and melodies with the horns as we ride down the road :grin: This would be several hundred beeps in a couple minutes. Riding on a closed coarse and we are the professionals :twisted: no problems yet.. other than I replaced my little stocker horn with a freeway blaster... :wink:
  15. plus one on the graphite :wink:
  16. Looks like a scuff that can be buffed but also showing 3 or 4 places that went to the plastic.. I kept putting layer of paint from the marker onto my spots that went to the plastic to built the area back up to make it look even.. You can't tell on mine unless you are within 2 feet of it looking right at :wink:
  17. Go to walmart, and visit the crafts section and look for a silver marker. its called "PAINTERS" and should have metallic written above the word painters.. It almost a perfect match for the silver. I had to use it on my right side after a little "OH SHIT" my bike fell over :roll:
  18. alot of people are getting wobble with the new Avons.. My problem was placement of the wheel weights from the grease monkey from the bike shop.. I had them rebalanced and head shake is completely gone :wink:
  19. My problem was fixed with yanking the weights off, and have to stupid ass grease monkey rebalance them.. I marked the weights and he had them placed over an inch off from the first balance :roll:
  20. got a buddy of mine with a 86' or 87 ninja 600 he is giving to me.. he is all Harley now.. so wants to get rid of it.. I wouldn't give the guy .30 cents for a bike that has that many worries or problems
  21. also try to not fill the tank up so much.. leave alittle bit of a air pocket :wink: Especially with the summer and heat the gas will expand and go out the overflow making you think you have a gas leak :wink: Or making a fire hazzard
  22. Hmm, might have a vent problem with your gas tank.. once you fill her all the way up she don't have much air in there. With your vent blocked not letting air in to replace the fuel being sent to the engine you cause a vaccum and this stops flow of fuel... Check you gas cap and make sure no dirt or crude is blocking anything.
  23. yep back of the tank.. they are usually covered by a huge ass washer 3 inch bolt 12mm head I do believe :wink:
  24. I wouldn't mind loosing alittle mid range.. I wanted to get alittle more free flowing exhaust. But also don't wanna burn up my exhaust valves in the process. :grin: I noticed the exhaust shape when laying on the ground changing my oil the first time.. I thought the stocker would benifit from a more ( Y ) shape pipe than the stocker with its exhaust coming to a dead end and being forced to go either left or right :???: At least I know why honda made such a funny looking exhaust pipe now and the purpose behind it Going to do some searching for that 2Bros pipe and see what I come up with.. If I do anything it will be a winter mod project... with riding season here I am too busy wanting to ride right now...
  25. Thats bullshit.. Buddy of mine works the parts desk at the local Honda shop. He can look up every nut, bolt, and washer. He spent one full day of being bored and selected every part number you would need to built a RC-51 from the the ground up buying the parts from the dealer. Think the total bill was almost $49,000 :roll: talk about price gouging
