Mikey Posted February 4, 2008 Posted February 4, 2008 If you have an X11 CCT kicking around and want to part with it, please let me know. I've got a cct rattle that doesn't seem to be solved by a standard CCT and want to cover all the angles before panicking. Quote
Hobicus Posted February 5, 2008 Posted February 5, 2008 If you have an X11 CCT kicking around and want to part with it, please let me know. I've got a cct rattle that doesn't seem to be solved by a standard CCT and want to cover all the angles before panicking. Mikey gets first dibs... But I, too, am looking for an X-11 CCT. My "Double Green Dot" CCTs start to rattle when replaced after about 5k miles or so and I'm getting tired of replacing them. I really don't want to deal with a "manual" CCT. I had replaced the stock one with an X-11 CCT on my original XX, and 50k miles later it was still quiet. Quote
lexxus Posted February 6, 2008 Posted February 6, 2008 I have one i no it. But you know how it is.So when i stop looking for it now. I will let you know when iam not looking and find it. I'll pm asap! :icon_wall: Quote
willxx23 Posted February 12, 2008 Posted February 12, 2008 If you have an X11 CCT kicking around and want to part with it, please let me know. I've got a cct rattle that doesn't seem to be solved by a standard CCT and want to cover all the angles before panicking. Mikey gets first dibs... But I, too, am looking for an X-11 CCT. My "Double Green Dot" CCTs start to rattle when replaced after about 5k miles or so and I'm getting tired of replacing them. I really don't want to deal with a "manual" CCT. I had replaced the stock one with an X-11 CCT on my original XX, and 50k miles later it was still quiet. bump Yeah bump and ditto what he said.....besides I like being in line behind Rich... Quote
lexxus Posted February 12, 2008 Posted February 12, 2008 Got It!! Damn it when you look'n you can't find. Stop looking and BAMM. $45.00 shipped also comes with new gasket. mikey ur up. Quote
Mikey Posted February 12, 2008 Author Posted February 12, 2008 Is it the X11 cct? If so, I'll snag it. I've ordered an OEM until I can find one of dem, der fancy ones. I've pm'd you some queries. Quote
SR71BLACKBIRDXX Posted February 13, 2008 Posted February 13, 2008 Before you go through the hassle, try one more...This worked for me. Maybe a fluke, but worth one more try... Everybody orders the the lifter set..which is part #..06140-MAT-315. This comes as a kit with the gasket and washers. If you look in the DEALER fiche..it says that this set is for 98, 99, and 00 XX's. I ordered part #...14520-MAT-E21 which says its for 01, 02, and 03 XX's. It comes with only the tensioner.I installed this one, rode it for 8000 miles with no rattling. Worth a try... Quote
John01XX Posted February 13, 2008 Posted February 13, 2008 Good thought Mike. I thought the same thing over two years ago and had Honda Directlines Owner, a friend of mine, do the research and sent out some email inquiry's only to find out that the Lifter itself is the same item from Honda just a different part number due to the way it is packaged and sold. Quote
lexxus Posted February 13, 2008 Posted February 13, 2008 The kit i have was from a group buy of the X11 cct. The part # at the time 14520-mcc-601 Gasket # 14523-mal-a00 These numbers are on the original packages and unopened in bubble wrap. Quote
Mikey Posted February 13, 2008 Author Posted February 13, 2008 I'm snagging it either way. If I happen to have two of the same, fine. Obviously I'm chewing through them. If I luck out and get the geniuine X11, then I've got a second as a backup. Either way I'm smiling! And the combined cost is CHEAPER than the OEM here locally. Quote
SR71BLACKBIRDXX Posted February 13, 2008 Posted February 13, 2008 Good thought Mike. I thought the same thing over two years ago and had Honda Directlines Owner, a friend of mine, do the research and sent out some email inquiry's only to find out that the Lifter itself is the same item from Honda just a different part number due to the way it is packaged and sold. Well like I said I wasnt sure if I just got a "good one" or not. After 2 Blackbirds, @ 40000 miles between them, and probably 6 tensioners, That one was the quietest. Quote
