RXX Posted January 10, 2007 Posted January 10, 2007 I installed mine last winter and never got it to fire up. All the diagnostics point toward the control switches, but I cannot find how to diagnose it. If any of you guys have one installed, and are using the speedo sensor, please let me know what your DIP switches are set to. Also, if anyone will loan me a control, I would like to swap it out for a few days. Otherwise, I am greedily eyeing all that real estate the servo is setting in under the cowl. I could put a kegerator or something in that hole. Thanks for the input!! Quote
bartonmd Posted January 10, 2007 Posted January 10, 2007 Mine works just fine... Use it about every day... I'm using the tach sensor only though... What EXACTLY is, or isn't it doing?? I had some issues with the power for the unit turning on when I didn't want it to, because when it said "the brown wire should be switched power" I hooked it up to switch power, but that was just info to test the unit, not how to hook it up... IMO, the directions kindof suck... Mike Quote
