Venus97 Posted January 2, 2007 Posted January 2, 2007 Hey Guys, I was thinking of getting a jet kit for my Bird and was wondering if there are certain brands I should look for, or avoid. Thanks. Quote
86gn Posted January 2, 2007 Posted January 2, 2007 I used a Factory Pro jet kit with good results. Quote
bartonmd Posted January 2, 2007 Posted January 2, 2007 I used a Factory Pro jet kit with good results. Yep... Every Dynojet kit I've used, I have not been able to get rid of the bog off idle, but the Factory pro kit worked Perfectly, and still gets good mileage! Mike Quote
sokanxx Posted January 2, 2007 Posted January 2, 2007 I have a Dyno Jet, I also have a slight bog off idle. the flat spot in mid range is eliminated but i do have a slight bog off the bottom Quote
blackhawkxx Posted January 2, 2007 Posted January 2, 2007 I have the Dyno Jet kit with perfect results. Quote
blackmax Posted January 3, 2007 Posted January 3, 2007 I have a Factory Kit on my 97 with a K&N filter and 4 into 1 with a Two Brothers counter measure can. It still gets 40 mpg . Quote
06Busa Posted January 4, 2007 Posted January 4, 2007 Factory is much more adjustable. factory pro site Quote
Venus97 Posted January 5, 2007 Author Posted January 5, 2007 Thanks for all the suggestions. (Seems like everything is due at once- tires, valve adjustment, chain/sprockets in the not too distant future) Quote
