OKblackbird Posted December 31, 2006 Posted December 31, 2006 I have noticed a few different websites listing two different reg/rec for my year bird 1997. The current reg/rec on the bike only has one wiring harness. I would apreciate advise on the correct unit or part number if available? I also will be replacing the stator which has gone bad and the battery the main culprit for this problem. Is it a bad idea to upgrade the battery to a Yuasa YTX-14BS it has more cc amps and is only a little bit taller. Will the extra a.h. draw be an issue for the stock reg/rec and stator. All help and comments are highly appreciated. I miss my bird!!!! John Findley Quote
Para045 Posted December 31, 2006 Posted December 31, 2006 I have noticed a few different websites listing two different reg/rec for my year bird 1997. The current reg/rec on the bike only has one wiring harness. I would apreciate advise on the correct unit or part number if available? Looks like one has been superceded by another part #http://www.ronayers.com/fiche/200_0351/wir...amp;parent=5570 & http://www.ronayers.com/browseparts.cfm?se...g=31600-MY7-600 I also will be replacing the stator http://www.ronayers.com/fiche/200_0351/alt...amp;parent=5570 which has gone bad and the battery the main culprit for this problem. Is it a bad idea to upgrade the battery to a Yuasa YTX-14BS it has more cc amps and is only a little bit taller. Will the extra a.h. draw be an issue for the stock reg/rec and stator. All help and comments are highly appreciated. I miss my bird!!!! John Findley Quote
OKblackbird Posted December 31, 2006 Author Posted December 31, 2006 I have noticed a few different websites listing two different reg/rec for my year bird 1997. The current reg/rec on the bike only has one wiring harness. I would apreciate advise on the correct unit or part number if available? Looks like one has been superceded by another part #http://www.ronayers.com/fiche/200_0351/wir...amp;parent=5570 & http://www.ronayers.com/browseparts.cfm?se...g=31600-MY7-600 I also will be replacing the stator http://www.ronayers.com/fiche/200_0351/alt...amp;parent=5570 which has gone bad and the battery the main culprit for this problem. Is it a bad idea to upgrade the battery to a Yuasa YTX-14BS it has more cc amps and is only a little bit taller. Will the extra a.h. draw be an issue for the stock reg/rec and stator. All help and comments are highly appreciated. I miss my bird!!!! John Findley Thanks for all the help will be ordering in the morning. Quote
