After loosening axle, tightening chain (adjusters)...I torqued the axle to spec
Do I then lightly "tighten" the ajusters as in rightie tighty?
I think I may have done something wrong....tightened chain and when I left work....checked the chain and that sucker was VERY loose. Axle was tight but right adjuster wasn't.
??? So I guess I want to know what direction to tighen the adjusters after I'm done adjusting the chain and have re-tightened the axle.
FYI....chain has 19500 mi (original)
thx
As you have probably guessed, you really needed to snug the adjusting bolts in a counter clockwise direction (lefty-tighty in this case) so that you are pushing the axle adjusting collars back to the rear, against the pull of the chain tension. By snugging them clockwise, you actually helped pull the adjusting collars into the swing arm and allowed the chain tension to take up the slack under acceleration.
Sell it and buy a cruiser!
:icon_biggrin:
Josh....a restraining order is coming your way! :icon_whistle:
Thanks, Fixx
You need a new chain.
+1
wow 19 1/2 thou on the chain..................how much adjustment do you have left?
your tires being cupped is the problem........................or is it your cups are tired?
You might want to check some other things before your done working on your bike Barry!!
IPB Image
It is a sad, sad thing that not enough attention is paid to the critical muffler bearing... such non-chalant complacency has been the source of frustating mechanical heartache for untold generations... But you can make the difference... Send your donations (cash preferred) to the Mechanics Anonymous Muffler Bearing Organization (MAMBO) through your local FreePlumbers Lodge - they'll see to it that your contribution is used wisely... Don't wait another minute - don't let another forelorn muffler bearing slip into race failure oblivion. :icon_hand:
A muffler bearing is a terrible thing to waste. :icon_nono:
IPB Image
OMG.............................................ROFLMAO!
What he said.
For what it's worth I got 24K miles out of my last chain, but it was definetly toast. If you snug the adjuster as mentioned and you still have to keep tighting it up, time for a new chain.
Great photo Randy..
