XXSTAR Posted December 22, 2006 Posted December 22, 2006 is the wire harness off a 01' XX the same as a 99' thanks Ron Quote
jjp1100xx Posted December 22, 2006 Posted December 22, 2006 is the wire harness off a 01' XX the same as a 99' thanks Ron The wiring harness is the same for a '99-'00, however it changed in '01. The wiring harness is the same for '01-'03. The wiring harness is divided into 43 parts. What do you need? is the wire harness off a 01' XX the same as a 99' thanks Ron The wiring harness is the same for a '99-'00, however it changed in '01. The wiring harness is the same for '01-'03. The wiring harness is divided into 43 parts. What do you need? is the wire harness off a 01' XX the same as a 99' thanks Ron The wiring harness is the same for a '99-'00, however it changed in '01. The wiring harness is the same for '01-'03. The wiring harness is divided into 43 parts. What do you need? Quote
XXSTAR Posted December 22, 2006 Author Posted December 22, 2006 I was thinking the 01' would be a up-grade. and not have the f1 problem. Quote
jjp1100xx Posted December 22, 2006 Posted December 22, 2006 I was thinking the 01' would be a up-grade. and not have the f1 problem. Not without a major rework. Quote
