XXMAN Posted August 2, 2003 Posted August 2, 2003 Right turn signal quit working it clicks more rapid than normal no lights any ideas? :idea: Quote
Warchild Posted August 2, 2003 Posted August 2, 2003 This behavior is consistant with a burned out bulb. Either your right front or right rear turn signal bulb is smoked. Replace it, and the turn signal "rate" will return to normal. Quote
hjacobs Posted August 2, 2003 Posted August 2, 2003 A connection to the bulb could of came loose Quote
XXMAN Posted August 2, 2003 Author Posted August 2, 2003 kept playing with bulb have running lights no signal tried different bulb still rapidly clicking no flash for turnsignal. Quote
XXMAN Posted August 2, 2003 Author Posted August 2, 2003 I was changing to silver bulbs because of clear turnsignal lens it was working fine pryor took bulb out an reistalled new ones worked fine used tape to stop running lights took one out and reinstalled and now turnsignal will not work checked connections in the faring they are all tight. :banghead: Quote
XXMAN Posted August 3, 2003 Author Posted August 3, 2003 Turnsignal socket was bad thanks for all your guys help. $13.00-14.00 part if anyone cares Thanks again. :shoot: Quote
