ConqSoft Posted July 26, 2003 Posted July 26, 2003 1) Are there Ohlins forks available for the XX? (I assume Yes?) 2) If #1 is Yes, does anyone here have them installed? Impressions? Quote
birdie_xx Posted July 26, 2003 Posted July 26, 2003 I've tried to order the springs. They only have the 0.95 kg ($109).... Took several months and they never arrived :cry: They also have a fork valve kit ($320) but I don't know how many parts are included (compression and rebound, or just compression ?) You can call Ohlins at 828-692-4525, and ask for Jerry. Hopefully you'd have more luck than I.... (the kits are here, the springs were coming from Sweden - now I was told it would take two-three weeks.) Hope this helps, good luck ! Quote
AlphaBird Posted July 27, 2003 Posted July 27, 2003 1) Are there Ohlins forks available for the XX? (I assume Yes?)2) If #1 is Yes, does anyone here have them installed? Impressions? Conq---I couldnt find any Ohlins forks for the XX---doesnt mean the dont exist--call Dan, hell know FYI--the 1.05 springs he put in my XX were Ohlins--I bet the Ohlins valving is the same as the F4i--again Dan will know Quote
