The sheets I've seen have mostly been in the 125-140 range.
155-160? I wish- maybe at the crank, but not at the wheel.
135-140 if everything is working right at the time (weather conditions, tire choice, oil viscosity, state of tune, etc.)
Some guys have run lower, and a select few higher, but most are in that range.
Redbird is right, that 160BHP number you see is at the crank, not the rear wheel.
Down 3 HP..... :twak: See I told you to put WD-40 on the chain.... but did you listen..... NNOOOOoooooooo! :razz:
WD-40???
thought it will spoiled the ring in the chain??? :roll:
