scubajohn Posted May 30, 2003 Posted May 30, 2003 http://cgi.ebay.com/ebaymotors/ws/eBayISAP...item=2417191409 1995 Honda cbr900rr cbr 900 rr tc fox shock I thought I read somewere that the 95 shock was the same ? or does it have to be sent out and re valved for the extra weight. I assume you would have to change the spring also right. Quote
Northman Posted May 30, 2003 Posted May 30, 2003 Should work fine. Just make sure you ask about the center to center distance between the mounting holes (12.5 inches is the correct measurement), and you will need a spring rate of 16-16.5kg, depending on your weight. Quote
