cbrxxquad Posted August 20, 2008 Posted August 20, 2008 I have seen a lot of changes to the bird that people have done. I have come up with a way to get info that will cross and get some feedback on the handling. It requires a standard mesurement system. Evlxx and I was trying to do some crosschecking on our bikes and came up with a place that should give a refrencing point to work off of. I want to see if I can get some info from everybody. But, not everbody will be able to as you will see. On the centerstand( eleminated a lot of people there) the distance from the front lip of the body to the ground. How much distance from the rear tire to the ground. So far, zxxx 6.00 front .5 rear zxxx 6.00 front 0.0 rear (Mod to rotate zx shock out of the way of the coolant res.) evlxx 6.5 front (forks dropped 20mm) .5 rear (3mm shim) lexxus 6.25 front(forks droped 25mm 0.25 rear (6mm shim) Please add your info to this post even if it is the same. Also if I have yours wrong correct what I have on here. I would like to begin to see if all are the same or vari a little. Also need stock mesurements. If you need a board under the center stand to get mesurements. Hopefully we can get to a handling discussion with this info. Quote
JuXXtin Posted August 20, 2008 Posted August 20, 2008 '99 Front... body work is off right now, can fill in later. Rear... 1 1/8" from tire to ground. Stock. Quote
spicholy Posted August 20, 2008 Posted August 20, 2008 Assuming front lip means lower edge of the chin cowel, 6.5" front. Rear tire about .5 inch. The rear tire is a Pirelli Diablo with +- 8500 miles on it and at the wear bars. Bike is a stock '99. All suspension stock. Quote
EVLXX Posted August 21, 2008 Posted August 21, 2008 Just had a thought... great would be to have 2 sets of numbers... 1st set, bike on the center stand. 2nd set, with rider off the center stand, in riding position. ... Quote
cbrxxquad Posted August 22, 2008 Author Posted August 22, 2008 Just had a thought... great would be to have 2 sets of numbers... 1st set, bike on the center stand. 2nd set, with rider off the center stand, in riding position. ... Yes, just need 0 for the rear tire number With the rider weight, going to need somebody to hold the bike and somebody to measure. Need a place, like the top of the rear bodywork faring..Whats ya think? Farther away from the axle the more acurate it needs to be. I guess in front of the rear wheel, frame to ground. that would be good for the centerless guys too Quote
jon haney Posted August 24, 2008 Posted August 24, 2008 6.5 inches at the front and 5/8 under the new rear tire with a 4mm shim on the shock. Quote
Dragonslayer Posted February 7, 2011 Posted February 7, 2011 Mine is 6.5" for the front and 0" for the rer tire. I have GP suspension forks and an Ohlins shock out back. Quote
FiXXation Posted February 8, 2011 Posted February 8, 2011 Front Chin - 6.5" Rear Tire - 31/32" off the ground Stock suspension all around, Michelin Pilot Roads with 3500 miles on them. It handles better than my VTX1300C. (Even though the battery won't stay charged indefinitely.) Quote
jon haney Posted September 18, 2012 Posted September 18, 2012 How about "measuring parties" at the various meats? That would insure plenty of people to help hold bikes for rider-on-board measurements. Quote
cbrxxquad Posted September 19, 2012 Author Posted September 19, 2012 How about "measuring parties" at the various meats? That would insure plenty of people to help hold bikes for rider-on-board measurements. I agree, loaded heights mean much more. Quote
EVLXX Posted September 20, 2012 Posted September 20, 2012 evlxx 6.5 front (forks dropped 20mm) .5 rear (3mm shim) That was before the " Project Upgrade"... As of today... with the 2008 ZX10R front forks and 2008 R1 rear shock with custom mounting brackets. The Lower cowl is 5.875" off the ground and the rear tire is around 0.250" or less off the ground. ... posting your sag measurements would be a good way to correlate ride heights with the above numbers... although I don't have mine recorded anywhere so... I would have to go out and remeasure them. Quote
