Posts posted by blackhawkxx
Great stuff. Does the tunnel affect the room in the bed? I don't think you showed a pic of inside the bed.
3 hours ago, SwampNut said:
That seems a bit weird. "Normal" things are pitas, pita chips (usually greasy and salty though), and veggies. Many people love raw broccoli with it (I don't really), and many other veggies.
Broccoli might be something to try. I can't eat raw broccoli (makes me want to gag) except when dipped in something. As far as "normal", I've never been accused of that. 🙂
- 1
6 hours ago, SwampNut said:
And you dipped what in it?
Something I try not to buy because I eat too many, tortilla chips.
- 1
You could try tapping the carbs to loosen things up if they are sticking.
I wonder if some of the float are stuck in the up position not letting the fuel fill the bowls?
QuoteVery partial turnover then nothing. Hit the starter and it sounds like its engaging but motor does not turn over.
Make sure you are working with a strong battery because even though it is turning over, I have found that my bikes get harder to start when the battery gets weak.
- 1
- 1
Corned beef hash, hash browns.
What brand hummus? Some, like Cedar brand, are bland garbage. Boar's Head and Sabra are pretty good.
Not sure what's there beside eggs but it looks good.
Hey I was living life on the edge today 🙂, bought garlic hummus and tasted it for the first time. It was meh but other flavors might be better.
3 hours ago, XXitanium said:
..the crew finally showed up at the neighbors. It's about twenty Mexicans.
Neighbor across the street had the same last year. They worked a couple hours after dark to get it finished. The boss or owner sat in his truck and watched the full time they were there without lifting a finger.
27 minutes ago, superhawk996 said:
No, the valve is in tact and normal. I added a piece of vacuum hose, the new and original hoses connect to eachother with a barb fitting just below the fairing on the left side. Since the bike sits a lot I wanted an easy way to drain the carbs. Before parking it I disconnect the hose which shuts off the fuel flow so I can run the carbs dry. When I want to start it again I suck on the hose connected to the diaphragm to prime the carbs instead of cranking a long time. Then I reconnect the hoses and fire it up.
If the diaphragm were to fail while parked it would empty the tank onto the ground instead of into the engine. I originally planed to use a tiny ball valve, and as often happens I couldn't find it when I wanted it so I just did the barb fitting as a temporary fix...about a year ago.
This is the bike I have seen parked in front of your living room fireplace? 🔥
- 1
- 4
4 hours ago, superhawk996 said:
If/when the diaphragm goes bad gas can go through the vacuum hose straight into the intake port.
A bad float valve 'should' send the excess gas out of the overflow onto the ground.
Right, forgot about that.
QuoteActually, I just realized that mine can't because I've by-passed the vacuum line.
So did you remove the the diaphragm?
The carbed bikes could become flooded due to a failed fuel shut-off valve.
But only if a needle valve stuck open. Thinking of all the bikes that didn't have a vacuum shut off and many people didn't close the manual valve.
5 hours ago, superhawk996 said:
and figuring that out 'should' only take two pages and three failed attempts.
And we are all willing participants.
There has to be some joke in this one about how many flat heads can be seen? 😁
- 1
7 hours ago, superhawk996 said:
Are you going to commit and cut the excess off the straps?
He might not want to do that if he is going to use them for when he hauls his mower or other things. Maybe after he tries it to see.
Congrats.
1 hour ago, SwampNut said:
That's almost as clean as Philip's bike.
The large round crash protectors on the side would be helpful to Phil. 😁
- 1
2 hours ago, rockmeupto125 said:
LOL, cut any corners for that shiny penny. It's not like anyone cares anymore about retaining customers. The metric is all about *getting* them, not keeping them.
I'm just going to buy the cheapest phone they offer, a moto g power. Had one, it was slow, but served
it's purpose.
Mine is coming on Tuesday, a 2024 which just came on the market last week. Through Cricket (current customer) it's about half price. I've seen the 2023 marked $100 off. My current Moto G7 Power is five years old and still working but slowing down. It had 3mb ram, the new 8 so it should be faster and is 5G.
Edit: sorry for blabbing in your post.
2 hours ago, SwampNut said:
Some states do have weird primary offense laws. For a long time, in AZ, you supposedly couldn't be stopped for not wearing a seat belt. You could be cited for it if stopped for another reason. Luckily, police would never make up a reason to stop you on some other pretext.
Same in Pa about seat belts or at least was but anyone is crazy to think they can't come up with a reason to pull you over.
Health issues, and their "solutions," have broad-reaching implications.
I didn't mean it as a put down and you are correct. My ignorance is bliss approach will probably catch up to me.
You guys have a complicated life.
4 hours ago, SwampNut said:
Rubber tape maybe?
That's a thought. Thanks.
Just now, SwampNut said:
Oh, that's a nice feature. I had to cut mine off, and it was oddly hard.
So every time I use the choke I have to use two hands. One to hold the pod, the other for the lever. Not that nice.
7 hours ago, xrated said:
I bought one years ago and it ended up breaking the control pod on the left grip side of the bike.
It broke the pin that keeps my left XX control pod from rotating.
41 minutes ago, Zero Knievel said:
Thoughts on this? It’s rated stronger and cheaper than the ones from Macs Custom.Like! Cheaper also
I need to start eating breakfast, but I really hate it
in Diet & health exchange
The wife is getting into the hummus thing and we ended up getting these plus pita chips and bread. The bread is really good but I don't eat bread, (can't control myself), the pita chips are harder than we like. I can eat all of them but the honey jalapeno is my favorite.
