RodeRash Posted April 11, 2003 Share Posted April 11, 2003 I'm having problems on my 97 BlackBird. I get a stumble just off idle. The bike runs and idles just fine, but when I start out easy, it feels and sounds like it drops to 3 cylinders, then picks right back up. If I have the bike in neutral, and rev the throttle, there is a hesitation right off idle, then it clears out. The exhaust system is stock. The plugs have around 6000 miles on them. I noticed this problem before I replaced the air filter. Replacing the filter did not help. Could this be a carb sync problem? Any other ideas? Quote Link to comment Share on other sites More sharing options...
Pete in PA Posted April 11, 2003 Share Posted April 11, 2003 If your idle is smooth, with no surgeing/hunting, then sync. should be on. Have you played with the pilot screw settings? If they are still at factory settings,turn them in till they seat lightly then out 2 1/2 turns. The factory has these almost shut off for emissions.These screws are on the bottom of the carbs and look like a circle with a small straight section. If you don't have the tool, try a .17 or .22 rimfire rifle case and put a slight dent in it at the rim. Quote Link to comment Share on other sites More sharing options...
RodeRash Posted April 11, 2003 Author Share Posted April 11, 2003 Thanks for the info Pete. This is a new problem. I am thinking that I may have a little gummy fuel in the pilot jets. I have only run a couple of tanks of fuel through the bike this winter. I am going to first try adding some BG44K cleaner to a tank of fresh gas to see if this will clear things up. If not, then I will pull the carbs, clean them, use your pilot jet settings as a starting point, sync the carbs, and then check the settings with an exhaust analyzer. If that doesn't work, I'll trade the bike for a newer one with FI Quote Link to comment Share on other sites More sharing options...
RodeRash Posted April 14, 2003 Author Share Posted April 14, 2003 Fixed the problem. Removed and cleaned the low speed jets. Didn't need to mess with anything else. Quote Link to comment Share on other sites More sharing options...
