JB4XX Posted April 25, 2014 Share Posted April 25, 2014 Loaded map Elton Fish had originally put in the 2001 Turbo bike. Very lean down low, I put one in to richen it up for a while, what do you guys think? Lean and mean or richen it up some down low? I also installed fresh set of plugs and fresh oil before a get it out this weekend and P L A Y!! Quote Link to comment Share on other sites More sharing options...
HANKSXXX Posted April 26, 2014 Share Posted April 26, 2014 Why do you think you need to screw around with the map?Are there driveability issues, fueling issues, or what? Generally speaking, I wouldn't make changes without at least a wide band that logged on the bike. That all has to work with specific fuel pressures, ignition timing, fuel, etc. Quote Link to comment Share on other sites More sharing options...
eliXXir Posted April 26, 2014 Share Posted April 26, 2014 AFR!!! Quote Link to comment Share on other sites More sharing options...
JB4XX Posted April 26, 2014 Author Share Posted April 26, 2014 Will check AFR and report back. After install, bike smoked on decel, cracked it open and found it missing part of piston ring, afraid /lean..detonation caused it. Quote Link to comment Share on other sites More sharing options...
HANKSXXX Posted April 26, 2014 Share Posted April 26, 2014 If you don't have data logging capabilities along with enough open road to air the bike out, find a tuner familiar with turbo bikes and have it tuned.11.5 AFR is a pretty safe target at full boost. Quote Link to comment Share on other sites More sharing options...
