GimPin Posted March 23, 2012 Share Posted March 23, 2012 I loosened the clamps that hold the carb set to the head ... is there anything else that holds these things down? I am trying to pull them off ... they wiggle back and forth a little but wont come off .... are they just stubborn? any tips? Quote Link to comment Share on other sites More sharing options...
brianmacza Posted March 23, 2012 Share Posted March 23, 2012 I loosened the clamps that hold the carb set to the head ... is there anything else that holds these things down? I am trying to pull them off ... they wiggle back and forth a little but wont come off .... are they just stubborn? any tips? I pulled my carbs last weekend to replace the jubilee clips on the thermostat housing. Get energetic - they hold on pretty well. Brute force is all I used, with some WD40 to get them back on. Quote Link to comment Share on other sites More sharing options...
MontanaXX Posted March 23, 2012 Share Posted March 23, 2012 I loosened the clamps that hold the carb set to the head ... is there anything else that holds these things down? I am trying to pull them off ... they wiggle back and forth a little but wont come off .... are they just stubborn? any tips? I pulled my carbs last weekend to replace the jubilee clips on the thermostat housing. Get energetic - they hold on pretty well. Brute force is all I used, with some WD40 to get them back on. Try pulling up on the carbs to pop the bottom of the carbs out first, that works best for me. Quote Link to comment Share on other sites More sharing options...
GimPin Posted March 23, 2012 Author Share Posted March 23, 2012 got em thanks guys ... put light to moderate prying presure with a flat bar under the bowls on both sides at the same time Quote Link to comment Share on other sites More sharing options...
slowrideCX Posted March 23, 2012 Share Posted March 23, 2012 They are stubborn little bastards for sure. Quote Link to comment Share on other sites More sharing options...
HANKSXXX Posted March 23, 2012 Share Posted March 23, 2012 They are stubborn little bastards for sure. You sure are..... Quote Link to comment Share on other sites More sharing options...
