partmonster Posted August 12, 2011 Share Posted August 12, 2011 I purchased the following bearing puller to repair the inside bearings on my Honda TRX500 swingarm: http://www.harborfreight.com/15-piece-slid...r-set-5469.html One side went easy with the tool right out of the box. Then after about an hour of the hooks slipping on the other side I took a closer inspection and noticed the hooks were not truly flat. The casting was quite rough. Took a file to it and flattend things out, and it grabbed right ahold of the bearing race and pulled it right out in about 4 slides. Hopefully someone will find this tidbit useful. Recommend for the $22 price (before all your coupon codes) if ya don't mind fixing what the Chinese couldn't do right the first time. Louie Quote Link to comment Share on other sites More sharing options...
RC Randy Posted August 12, 2011 Share Posted August 12, 2011 Good to know. I used their blind bearing puller to remove my rear wheel bearings and had no complaints. Quote Link to comment Share on other sites More sharing options...
