kiwimack Posted August 10, 2010 Share Posted August 10, 2010 At what temp will the cooling fan on a 03' kick in? Quote Link to comment Share on other sites More sharing options...
BobZ Posted August 10, 2010 Share Posted August 10, 2010 On my 2002, the fan kicks in at about 215 F. Quote Link to comment Share on other sites More sharing options...
Keith Posted August 11, 2010 Share Posted August 11, 2010 On my 2002, the fan kicks in at about 215 F. +1, same on my '03. Quote Link to comment Share on other sites More sharing options...
KaziXX Posted August 24, 2010 Share Posted August 24, 2010 On my 2002, the fan kicks in at about 215 F. +1, same on my '03. +1 on my '03 it goes off at 209 F. I see temps in the 220's and even up to the 230's. Quote Link to comment Share on other sites More sharing options...
Keith Posted August 24, 2010 Share Posted August 24, 2010 +1 on my '03 it goes off at 209 F. I see temps in the 220's and even up to the 230's. Interesting. Mine goes off at about 200. Also see as high as upper 220s; have never seen 230. Quote Link to comment Share on other sites More sharing options...
JB4XX Posted August 25, 2010 Share Posted August 25, 2010 Starts flashing at 255. Quote Link to comment Share on other sites More sharing options...
slowrideCX Posted August 25, 2010 Share Posted August 25, 2010 Mac check the temp sensor connection for any corrosion, Ruhi was getting erratic high temps and though he had a problem . We removed the temp sending unit and cleaned both the sensor and the electic plug put a little dielectic grease on the plug and it fixed the problem. Quote Link to comment Share on other sites More sharing options...
XXSIVSPD Posted August 25, 2010 Share Posted August 25, 2010 The weekend of WiXX I noticed mine getting hot quicker than usual with no leaks & normal coolant levels. After a quick peek at the radiator, I noticed I had picked up some of that cement like sludge from where they cut it wet in construction zones around here. That & a fair amount of bugs lodged in the fins. Also tested the coolant & noticed it's good to -50f. Power washed the radiator & added some water wetter. Much better now... Quote Link to comment Share on other sites More sharing options...
KaziXX Posted September 13, 2010 Share Posted September 13, 2010 Got up to 246F today! Quote Link to comment Share on other sites More sharing options...
