Aurora Posted April 6, 2009 Share Posted April 6, 2009 O2 Sensor Does a non CA 2003 XX have an exhaust O2 sensor? Quote Link to comment Share on other sites More sharing options...
Skull Posted April 6, 2009 Share Posted April 6, 2009 O2 Sensor Does a non CA 2003 XX have an exhaust O2 sensor? I don't think so. Why? Quote Link to comment Share on other sites More sharing options...
Aurora Posted April 6, 2009 Author Share Posted April 6, 2009 O2 Sensor Does a non CA 2003 XX have an exhaust O2 sensor? I don't think so. Why? I have a little surging around 3k to 3.5k RPM. This might be the point between lean to rich mixture from the ECU. If the bike's O2 senor is fooed, maybe the lean mixture can be removed for more power and smooth operation. Make_Your_Own_O2_Sensor_Eliminators___VFRD.pdf Quote Link to comment Share on other sites More sharing options...
Redbird Posted April 6, 2009 Share Posted April 6, 2009 Definitely no O2 sensor on any 49 state XXs. Quote Link to comment Share on other sites More sharing options...
Skull Posted April 6, 2009 Share Posted April 6, 2009 The O2 sensor is only used on cold start. The ECU doesn't operate closed-loop during normal operation (and it might not really even qualify as closed-loop during cold start, either). Quote Link to comment Share on other sites More sharing options...
Iceman_40 Posted April 6, 2009 Share Posted April 6, 2009 I have a little surging around 3k to 3.5k RPM. This might be the point between lean to rich mixture from the ECU. If the bike's O2 senor is fooed, maybe the lean mixture can be removed for more power and smooth operation. I had the same thing with pipes and K&N until I had the PC3 tuned for the bike. Quote Link to comment Share on other sites More sharing options...
