NoOne65 Posted September 10, 2008 Share Posted September 10, 2008 So, I have a bad regulator/rectifier. The voltage increases from 12v on up to 17v. It overcharges the battery to the point of boiling the liquid dry. I have a new R1 unit to be delivered tomorrow to replace the R1 unit already on the bike. My commute is small..about 20 miles...and I dont have any other transportation. Do you think that if I remove the hot lead from the R/R that the battery would be sufficient to make 20 miles, then get a full charge from a charger at home? J Quote Link to comment Share on other sites More sharing options...
Keith Posted September 10, 2008 Share Posted September 10, 2008 If the battery is fully charged right now and you pull the headlight fuse, you should be able to make 20 miles easily, even more likely if you have some one give you a bump start to save the juice used to start with the starter motor. Quote Link to comment Share on other sites More sharing options...
John01XX Posted September 10, 2008 Share Posted September 10, 2008 Pull fuse for Headlight push start and you are good to go more than 20 miles Quote Link to comment Share on other sites More sharing options...
NoOne65 Posted September 10, 2008 Author Share Posted September 10, 2008 Thanks for the info!! Quote Link to comment Share on other sites More sharing options...
CALCXX Posted September 16, 2008 Share Posted September 16, 2008 I had to nurse the XX home just a couple months ago. FYI, if your interested? http://www.cbr1100xx.org/forums/index.php?...mp;#entry632718 Quote Link to comment Share on other sites More sharing options...
NoOne65 Posted September 16, 2008 Author Share Posted September 16, 2008 I had to nurse the XX home just a couple months ago. FYI, if your interested? http://www.cbr1100xx.org/forums/index.php?...mp;#entry632718 Thanks Cal...I already had an R1 unit. I suspect the heat from my 4 hour Gustav evacuation from the city fried it. I replaced it with another and it works like it should, no rewiring necessary. Just need to remove the spades from the plastic connector. You can always save the connector if you wish to go back to stock Quote Link to comment Share on other sites More sharing options...
