Scated Posted November 26, 2006 Share Posted November 26, 2006 I think I know the answer but here goes: When I picked up my '02 Silver Bird it came sans the bolt that holds the fairing down below the kickstand. I've gove through the process of buying the bolt and finding a backing nut but I can't bring myself to put in on. It's a serious pain in the ass. What kind of design is that. I really can't see the necessity when I pull that lower left cowl on a pretty regular basis to access the oil filter. Am I alone here or just completely blind? Quote Link to comment Share on other sites More sharing options...
Redbird Posted November 26, 2006 Share Posted November 26, 2006 It's not a bolt there from the factory, it's one of those push pins. Mine went missing pretty early on, never to be replaced. Quote Link to comment Share on other sites More sharing options...
Scated Posted November 26, 2006 Author Share Posted November 26, 2006 It's not a bolt there from the factory, it's one of those push pins. Mine went missing pretty early on, never to be replaced. See now that makes perfect sense! Too bad the stealership, along with me peering at the fiche, couldn't advise me that that was a pin not a bolt. I'm sure they enjoyed selling me another $5 bolt! Thanks. Quote Link to comment Share on other sites More sharing options...
dunedain Posted November 26, 2006 Share Posted November 26, 2006 I just zip tied it on mine. Quote Link to comment Share on other sites More sharing options...
Venus97 Posted November 26, 2006 Share Posted November 26, 2006 I was able to change my oil and filter for the first time yesterday w/o having to take any of the fairing off. I had not noticed before (until I saw mentioned in another thread) that there is an opening underneath motor. I easy access to drain bolt and not as easy but do able access to filter. Quote Link to comment Share on other sites More sharing options...
HERBXX Posted November 26, 2006 Share Posted November 26, 2006 Yep, just use some channel lock pliers on the filter , there is no need to take off any body work. :icon_clap: Quote Link to comment Share on other sites More sharing options...
Northman Posted November 26, 2006 Share Posted November 26, 2006 It's not a bolt there from the factory, it's one of those push pins. Mine went missing pretty early on, never to be replaced. The original clip was one of those two piece ones with the plastic philips head screw in the middle. I replaced mine with the same push pin that the rest of the bike uses, and my OCD forces me to re-install it properly each time I remove the fairings. I still prefer to pull the fairings for oil changes. Much easier to get at what you need to, plus it allows me to clean up better when I'm done. Quote Link to comment Share on other sites More sharing options...
pug Posted November 26, 2006 Share Posted November 26, 2006 It's not a bolt there from the factory, it's one of those push pins. Mine went missing pretty early on, never to be replaced. +1, I have the habbit to overlube my chain and this part gets veeeery dirty. Put it back if you sell it.. PS: Tim , you are a brave man to admitt it openly. I wouldn't if you didn't Quote Link to comment Share on other sites More sharing options...
pug Posted November 26, 2006 Share Posted November 26, 2006 I still prefer to pull the fairings for oil changes. Much easier to get at what you need to, plus it allows me to clean up better when I'm done. By the way, here is a photo sequel changing oil & air filter on the Bird on my driveway (since my garage is for one car and very tight). The text is in Greek but if anybody finds it interesting, I could translate it.. Quote Link to comment Share on other sites More sharing options...
Pete in PA Posted November 26, 2006 Share Posted November 26, 2006 It's not a bolt there from the factory, it's one of those push pins. Mine went missing pretty early on, never to be replaced. +3 It's not necessary and a real pain to replace. I also don't have those 2 push pins in the front bottom. Quote Link to comment Share on other sites More sharing options...
Skull Posted November 29, 2006 Share Posted November 29, 2006 I just zip tied it on mine. This is a great solution, and it also works very well for the two holes that hold the fairings together at the front. Right now, I have bolts in there, but the zip tie is so much more convenient. Quote Link to comment Share on other sites More sharing options...
