panote Posted September 8, 2006 Share Posted September 8, 2006 How do I know (or feel) when engine is koncking or start to koncking when I use the lower octane (91 octane) Quote Link to comment Share on other sites More sharing options...
Flitemdic Posted September 8, 2006 Share Posted September 8, 2006 It shouldn't knock, the bike has an anti-knock mechanism. If you can hear it with that high of octane, something else is wrong. At least in my experience Quote Link to comment Share on other sites More sharing options...
Bandit XX Posted September 8, 2006 Share Posted September 8, 2006 as noted in previos thread the xx as a knock senser to revent knocking. if you think your bike is knocking, the easy way to tell is get out on the road and get in the higher gears at a low rpm about 2000 or 2500 and use near full throtle and if you hear a rattle pinging sound your running to low of octane or something else is the problem. the xx has 11 to 1 compresion and you should use 91 octain for best peformance,but I know alot of people run regular. Hope this helps. Quote Link to comment Share on other sites More sharing options...
panote Posted September 12, 2006 Author Share Posted September 12, 2006 Thank you....... as noted in previos thread the xx as a knock senser to revent knocking. if you think your bike is knocking, the easy way to tell is get out on the road and get in the higher gears at a low rpm about 2000 or 2500 and use near full throtle and if you hear a rattle pinging sound your running to low of octane or something else is the problem. the xx has 11 to 1 compresion and you should use 91 octain for best peformance,but I know alot of people run regular. Hope this helps. :icon_duh: I don't understand "use near full throtle" step Would you please explain this step to me. Quote Link to comment Share on other sites More sharing options...
