R1000 Posted August 25, 2006 Share Posted August 25, 2006 Hi, I'm new to this forum and have recently bought a Blackbird -97 here in Sweden. The bike runs real well and appears to be in good condition. When it's cold there is a noticeable rattle, which disappears as soon as the clutch lever is pulled in. Same phenomena when it's warm, but then there is almost no rattle when the clutch lever is out. Is this typical for a CCT problem or something with the clutch basket or even maybe quite normal? Quote Link to comment Share on other sites More sharing options...
Guest rockmeupto125 Posted August 25, 2006 Share Posted August 25, 2006 Its typical and has nothing whatsoever to do with the CCT. Quote Link to comment Share on other sites More sharing options...
R1000 Posted August 25, 2006 Author Share Posted August 25, 2006 Its typical and has nothing whatsoever to do with the CCT. Thanks, you meen its normal and nothing to worry about? Quote Link to comment Share on other sites More sharing options...
Iceman_40 Posted August 25, 2006 Share Posted August 25, 2006 Its typical and has nothing whatsoever to do with the CCT. Thanks, you meen its normal and nothing to worry about? Yep that's what he means, heavy duty cluch makes some noise normal and not a problem. If it goes away when you pull in the clutch just ride the bitch. Quote Link to comment Share on other sites More sharing options...
R1000 Posted August 25, 2006 Author Share Posted August 25, 2006 Its typical and has nothing whatsoever to do with the CCT. Thanks, you meen its normal and nothing to worry about? Yep that's what he means, heavy duty cluch makes some noise normal and not a problem. If it goes away when you pull in the clutch just ride the bitch. Thanks, I'm new to this bike and have a lot to learn Quote Link to comment Share on other sites More sharing options...
SBBXX Posted August 25, 2006 Share Posted August 25, 2006 Thanks, I'm new to this bike and have a lot to learn Stick around then. The amount of knowledge on this board is frickin amazing. Welcome to the dark side. Quote Link to comment Share on other sites More sharing options...
