RodeRash Posted July 13, 2006 Share Posted July 13, 2006 I was just wondering if anyone else gets noise from their cam chain when their engine is first started? It happens at a lower rpm than what is usually reported. (from about 2000-3500 rpm) It's the typical "bag-o-marbles" rattle. The noise goes away after a few minutes of riding. I replaced the original CCT with one of the X11 models maybe 20,000 or so miles ago. Quote Link to comment Share on other sites More sharing options...
SBBXX Posted July 13, 2006 Share Posted July 13, 2006 That'll be your clutch basket. Totally normal. edit: you can verify by disengaging the clutch, the noise should diminish considerably. Quote Link to comment Share on other sites More sharing options...
OrganDonor Posted July 13, 2006 Share Posted July 13, 2006 Are you sure it's the CCT, and not the clutch? Mine has the same "bag o'marbles" sound to it when I first start it in neutral. If I pull the clutch lever, it goes away somewhat. Quote Link to comment Share on other sites More sharing options...
Mikesblackbird Posted July 13, 2006 Share Posted July 13, 2006 I was just wondering if anyone else gets noise from their cam chain when their engine is first started? It happens at a lower rpm than what is usually reported. (from about 2000-3500 rpm) It's the typical "bag-o-marbles" rattle. The noise goes away after a few minutes of riding. I replaced the original CCT with one of the X11 models maybe 20,000 or so miles ago. Are you certain it is not the clutch basket? I get noise from the clutch basket, but not the CCT. Quote Link to comment Share on other sites More sharing options...
Warchild Posted July 13, 2006 Share Posted July 13, 2006 That'll be your clutch basket. Totally normal. True, the clutch basket makes a lot of noise rattling around when it's cold, but this noise should dissapear when you pull in the clutch. To me, RodeRash is describing a worn cam chain tensioner pretty accurately..... the "bag-o-marbles" discription is tell-tale.... Quote Link to comment Share on other sites More sharing options...
John01XX Posted July 13, 2006 Share Posted July 13, 2006 That'll be your clutch basket. Totally normal. True, the clutch basket makes a lot of noise rattling around when it's cold, but this noise should dissapear when you pull in the clutch. To me, RodeRash is describing a worn cam chain tensioner pretty accurately..... the "bag-o-marbles" discription is tell-tale.... $34.50 delivered to replace it Quote Link to comment Share on other sites More sharing options...
RodeRash Posted July 13, 2006 Author Share Posted July 13, 2006 It's definately not the clutch. The clutch makes a different noise. It's the cam chain. It acts like it takes a little while for the oil pressure to build in the CCT before it tensions properly. I might try an oil additive like BG EPC to see if this makes a difference. Quote Link to comment Share on other sites More sharing options...
tkyler Posted July 17, 2006 Share Posted July 17, 2006 and in reponse to my initial question...I came across the answer...having removed my side panels for the first time since acquiring the bike. The "very slight" rattling is coming from the cooling fan. There's a very small amount of play around the fan bearings...probably normal..but when going through 3500-4000 rpms...that frequency just gets that thing rattling. Quote Link to comment Share on other sites More sharing options...
