paslag Posted June 6, 2006 Share Posted June 6, 2006 Hi. I'm installing my hid kit and when I uninstalled my headlamp I did not check if the lower light is the low or the high beam :icon_wall: So my question is simple. Wich light is the low beam? The upper or lower? Thanks a lot Quote Link to comment Share on other sites More sharing options...
bartonmd Posted June 6, 2006 Share Posted June 6, 2006 wow... I guess I'll answer it anyway... The low beam is the top one... The one with the bulb you can't see unless you're below the headlight... The high beam is the bottom one... the one with the bulb you can see from everywhere in front of the bike... MIke Quote Link to comment Share on other sites More sharing options...
Warchild Posted June 6, 2006 Share Posted June 6, 2006 Another easy way to tell which is which is to turn on the ignition and ensure the high-beam switch is off. Once done, you'll know for sure that the sole remaining headlight that is still lit is the low-beam. Quote Link to comment Share on other sites More sharing options...
paslag Posted June 6, 2006 Author Share Posted June 6, 2006 Another easy way to tell which is which is to turn on the ignition and ensure the high-beam switch is off. Once done, you'll know for sure that the sole remaining headlight that is still lit is the low-beam. LOL! Iknow that. The only thing is I never check before wich is wich and know that I have removed the sealed beam I don't remember if the low beam was the upper or lower. Now I know! Thanks guys! Quote Link to comment Share on other sites More sharing options...
Obby Posted June 7, 2006 Share Posted June 7, 2006 The top is lowbeam. Quote Link to comment Share on other sites More sharing options...
