Headlight Fuse
vanbo
Guest rockmeupto125
Check BOTH plugs on the back of each bulb. Remove and clean the contacts and reinstall and make sure they are seated all the way!
Dave
Precisely.
If you've put high output bulbs in the headlight, you should know that others have had this problem.
Also, if you've removed the switchgear, you may have pinched a wire on reassembly.
Older bikes with a lot more wear than yours can get shorts in the controls, but I wouldn't suspect that being your problem.
