scott s. Posted June 8, 2005 Share Posted June 8, 2005 will the rc51 forks 2001 fit a bird if so what type of enginering is necessary to install them. brakes, lines, ect. thanks scott s. Quote Link to comment Share on other sites More sharing options...
RodeRash Posted June 8, 2005 Share Posted June 8, 2005 Dude, How many times are you going to ask this same question? With enough money and machining talent, you can make anything fit. Quote Link to comment Share on other sites More sharing options...
demon Posted June 8, 2005 Share Posted June 8, 2005 I don't feel like typing all this shit again, so I quoted myself From your other fork posting They'll fit. You'll need the lower and upper tripple clamps, front brakes and rotors, front brake lines, front master cylinder, clipons, fender, wheel, stiffer front springs for the added weight, and you need to delink your brakes. 1 Quote Link to comment Share on other sites More sharing options...
revlimitbounce Posted June 9, 2005 Share Posted June 9, 2005 is there a different filling procedure when using 91 octane vs. 87? also, when do you need to replace the piston return springs? Quote Link to comment Share on other sites More sharing options...
Skull Posted June 9, 2005 Share Posted June 9, 2005 If I get an integrated rear taillight, what is the % mixture between brake fluid and blinker fluid? Is it possible to over-torque the loose nut between the seat and the handlebars? Quote Link to comment Share on other sites More sharing options...
BDAZ XX Posted June 9, 2005 Share Posted June 9, 2005 How many miles before the muffler bearing needs lubed? Quote Link to comment Share on other sites More sharing options...
Red J Posted June 9, 2005 Share Posted June 9, 2005 I want to make my patio larger, where can I rent a concrete stretcher? Quote Link to comment Share on other sites More sharing options...
cbrxxquad Posted June 9, 2005 Share Posted June 9, 2005 the answer to your question is sky hook Quote Link to comment Share on other sites More sharing options...
