HERBXX Posted January 30, 2005 Share Posted January 30, 2005 Hopefully this will help with the cracks in the rear cowl , its just 1/2 inch tube with a nut welded in each end. Quote Link to comment Share on other sites More sharing options...
birdie_xx Posted January 30, 2005 Share Posted January 30, 2005 Cool ! Can you make more of them ? :wink: Cheers, Quote Link to comment Share on other sites More sharing options...
HERBXX Posted January 30, 2005 Author Share Posted January 30, 2005 Mabe . but im not really set up to reproduce anything. Im more into concepts then production , but if you can't find one closer to home we can work somethingout. If i could get some threaded insert cheap some where it would help, mabe i could use t-nuts, The tricky part is to get the length dead on. IF was going to build a few i gues i could build a bit of a jig . It also could made of of aluminum rod with a hole drilled and taped in each end . I used bolts left over from my givi mounts, i dont really have a good source of cool hardware. Herb Quote Link to comment Share on other sites More sharing options...
Keith Posted January 31, 2005 Share Posted January 31, 2005 What problem is this trying to solve? Is cracking of the rear cowl a common problem? I haven't seen anything about it on the list. Quote Link to comment Share on other sites More sharing options...
HERBXX Posted January 31, 2005 Author Share Posted January 31, 2005 It happens, I think most often when additional racks are involved. I caught mine when it was just under the grab rail and was in invisible without removing it, othershave also reported it . That area of the subframe is not very strong against lateral loads. I figure it cann't hurt and will help prevent some of the flexing that may be causing the cracks. Herb Quote Link to comment Share on other sites More sharing options...
