The Krypt Keeper Posted December 30, 2004 Share Posted December 30, 2004 Is there a electrician in the house? I was looking at some single LED's, at Radio Shack, these were alot bigger than most I have seen. Some where 10mm, where more common ones are 5mm. I was thinking about making some little stuff using LED's but was curious on what you need. I know you can't wire them straight to a bike battery, so how do you know what resistors and what not you need? You get with different LED's telling you that the typical voltage might be 1.8 volts, and a max of 2.2 volts, and what about all the mA? Milla amps vary also.. How would you hook up say, 4 or 5 in a row? or in a cluster? Quote Link to comment Share on other sites More sharing options...
Mikey Posted December 30, 2004 Share Posted December 30, 2004 When I did my break lights I did this: ((# of leds)xamperage)/offered voltage (ie 13) that will give you your resistor value. Get as close as c you can. v over i times r. Quote Link to comment Share on other sites More sharing options...
bartonmd Posted December 31, 2004 Share Posted December 31, 2004 If I remember correctly, LED's take about 15mA... making 14.4/.015 = about 1kohm (960 actually, but you know...) for 1 LED... multiply the ".015" times however many LED's you have and if you have several, you will probably want to go with at least 1/2 or 1 watt resistor for them! You are FAR better off just doing 1 1/4 watt resistor PER LED though... that way, if you get one LED that is a lower voltage (resistance) and takes too much current for itself and burns out, you don't get mass suicides of your LED's. hope that helps... Mike Quote Link to comment Share on other sites More sharing options...
The Krypt Keeper Posted December 31, 2004 Author Share Posted December 31, 2004 I think the LED's I was looking at were 20mA's.. Its been a while since I did electronics in High School.. I am slowly refreshing my memory :roll: I might try my hand at this and make some custom turn signals for the blackbird, or whatever I feel would be neat to make.. I love building stuff so I will have fun.. I am sure I will be back with some questions.. I just need to get me some supplies.. strip board, led's resistors, ect, ect,.. Thanks again Quote Link to comment Share on other sites More sharing options...
