Posts posted by John01XX
Thanks Dave,
Not gonna sell it till the new V-5 comes out next year.
I just want to stop and go for now.
I just had the front lower fort tubes powdercoated on my 2001 Red (fastest) Bird. Also at the same time had a set of HyperPro progressive front springs installed. The powder coating looks great and the front spring made the handling MUCH improved. BUT now the front brake seems to be rubbing intermittantly when I come to a stop just lightly.
If I step on the back brake quickly when stopped it seems to release the front. I have a hard time pushing the bike backwards out of a parking spot if I don't tap the back brake first.
Could it be something to do with the mechanical tie between the front and rear ? Where Should I be looking to free up the front caliper or whatever to get them back to normal ?
Anyone ever experienced this before?
Check out the Champion Industrial line. We sell them to the Car Wash industry. Check them out on our website : www.sonnysdirect.com
For pricing I can fax you a price sheet if you pm me a fax number.
Thank you
Thank you
Can anyone verify the part number for the Alternator cover Gasket for the Bird is 11392-MAT-000 ?
I can't pass this one up. As a professional in the Car Wash Industry, I can tell you the dull finish as said in the thread is a scuffing of the clear coat from the abrasive rubbing of the leather. It can be polished out fairly easily with most any good quality polish.
Honda spray polish is technically Not a polish but instead a cleaner and protective wax. A true polish has some sort of abrasive material in it, either chemical or physical.
When Polishing any surface you have to spend alittle time rubbing the surface vigorously, just like shinning up aluminum. Waxing is done for protection and is only Applied and then lightly buffed.
Fine scratches must be rubbed out. I would never recommend using an abrasive polish below 3000 grit on the clear coat of a bike, since you will be thinning out the clear coat and will not leave enough when done to maintain any protection in the future.
Scratch's can only be removed by lowering the surrounding clear coat to the depth on the scratch. If scratch's have any depth to them, then another layer of clear coat would need to be applied. That is why nice looking show cars are wet sanded first then polished to a brilliant shine and then waxed to maintain it.
There many good quality polish's on the market and for the best results, the use of micro-fiber with a good polish will do the best job in the least amount of time.
Just ask DBLXX Dave about the ability of micro-fiber to clean and shine a clear coated finish without ever leaving any scratch's or even lint behind.
Did I say "behind" ? oops I won't go there !!!
Turbos
Velocity racing is who makes the Turbo's at www.velocityracing.com
Kents race Bike has a power to weight ratio of 1 to 1 !!!!
505hp and racing weight of 505lbs. And he dose NOT have to rebuild the engine after every race weekend either.
Worlds fastest Street Bike "Bar None"
No wheelie bar. He rode it on the street on the Thursday night at the Honda Hoot this year.
His personal Bird is a Fast RED One (2001) with a Velocity Racing turbo .
8 lbs of boost gives him 262 hp and, as Joe said, all on stock cranks and tranny.
Impressive Turbo's on an impressive Bike.
the XX CCT 06140-MAT-0315 or maybe without the "O" (06140-MAT-315) is readily available from Honda. I have bought a few from my local dealer and sent them overseas for a friend and are under $30.00
I use my own personal web page as provided by BellSouth.net
Works fine but I only get 10 mgs of storage
X11 (Naked blackbird) CCT: 14520-MCC-601
XX CCT: 06140-MAT-0315
I had my swing arm drilled and taped. Spools have worked great for almost 2 years now in conjunction with the Pit Bull rear stand. No problem for this skinny 150 lb weakling guy to put it on and off the stand by myself.
I had that problem once. The only time I have let someone else do an oil / filter change for me. I learned the lesson and do my own always now.
I ended up buying a filter removal tool that looks like a pair of channel locks but has rounded jaws that fit the filter. With them I can only get a 1/8 turn before hitting the pipes but it works great to break it loose. Got it at a local auto parts store for about $5.00.
Troy,
I also just ordered a progressive spring kit from www.hyperpro.com
Actually I ordered mine through www.whitebuffaloracing.com/hyperpro.htm since it was 15.00 cheaper. I am waiting their arrival. Paid 164.00 total for the springs and Maxima fork oil including shipping. Hopefully will be here on friday.
That is where I got mine from too. In stock, recieved in 3 days.
D.I.D. ZVM X-Ring Chains PHOTO
Order # Price...... Description......
(58347) $114.95 D.I.D. 530ZVM X-Ring Chain 100 Links Closeout
(58348) $116.95 D.I.D. 530ZVM X-Ring Chain 102 Links Closeout
(58349) $118.95 D.I.D. 530ZVM X-Ring Chain 104 Links Closeout
(58350) $121.95 D.I.D. 530ZVM X-Ring Chain 106 Links Closeout
(58351) $123.95 D.I.D. 530ZVM X-Ring Chain 108 Links
(58352) $125.95 D.I.D. 530ZVM X-Ring Chain 110 Links
(58353) $128.95 D.I.D. 530ZVM X-Ring Chain 112 Links
http://www.hipersports.com/did.htm#Chains
scroll almost to the bottom
DID ZVM530 is the Dogs Dangles !
It is a fairly common problem. It is usually a bad connection (ground). Mine was found immediately by the Honda dealer using their diagnostic computor. Check various grounds for loose connection.
Jason,
You can buy spray tint in an aerosol can but it doesn't work very well. Runs real easy, so you have to apply multipule light coats till you get the darkness you want. But it scratches real easy too. You would be better off buying a smoked screen.
As Mick said, the MRA screen is probably the finest screen you can buy for the Bird and doesn't have much more rise than the newer model stock screens. I have a Powerbronze that I bought when I was in England for the Bash this year and it is a tall screen, but I love it since I am another old fart that doesn't do alot of deap tucking-in. The MRA is probably the favorite in Europe except for the price.
"Pit Bull" Pit Stand works well for me since I took off my center stand for the Full Akropovic Race system.
Good decision. You do want the ZVM. Check to see what they will charge you to install the ZVM for you just to avoid the purchase of the Chain riveter, maybe. The ZVM comes with the riveted master link.
put a small 1/4" piece of black electrical tape over the contact on the bottom of the bulb, then twist the bulb in place
As Vern showed me at the Hoot
PepBoys is the place for the Titan Bulbs.
Instead of cutting the wire to the bulb, just do what Vern recommended and I did also, which is put a small 1/4" piece of black electrical tape over the contact on the bottom of the bulb, then twist the bulb in place. Very stealthy and easily removed if change is desired. No Cutting of wires.
Also I assume you have the Clear Lenses already. I still offer a 20% discount on Clear Alternatives lenses for members here.
I just installed the DID ZVM530 last weekend. That is what comes on the BIRD stock. Made for bikes over 1000 cc. Only thing is it does not have the Gold side bars. I was told the standard VM530 as recommended for the 954 will work just fine and it has the gold sides but the ZVM is a higher tensil(sp) strength. I went with the best I could find.
Also I believe you should always go with Steel sprockets. About the same price as the hardened aluminum ones but last alot longer. Aluminum sprockets are for racers that want to lose weight. The aluminum are lighter by a few grams, not sure how many but makes no difference on the bird. With the Bird's power you need strength. Stick with the steel sprockets like stock ones are.
I always try to send my business to a fellow Bird Rider if possible especially when they are as good a person as Jaws is.
100W Headlight?
I emailed him to see if he carries any H7's for the Bird.
