Posts posted by John01XX
Brakes
As shown in the Manuel, you can bleed the linked brake system on the Bird properly and thoroughly without the use of a vacuum bleeder but it is a pain in the butt. The job will require 2 people and should not be attempted by yourself.
If there are no other issues other than air in the line, then the spongy rear should disappear, since a properly bled system will expel all the trapped air.
- 1
I agree with you with 2 exceptions!
I happen to actually kind of like the look even in Candy Glory Red!
1.2 gallons is just to much to give up.
Brakes
1 hour ago, blackhawkxx said:My guess is the diaphragm in the master.
+1 rubber diaphragm in the master cylinder
- 1
Brakes
Just a thought to throw into the mix. When you used the screwdriver against the old pads to push the pistons back, did you have the reservoir cap off?
It is a sealed system and when you push the pistons back the reservoir cap must be removed. If the cap is still on when you push the pistons back, you will create a problem. Sometimes the plunger gets turned inside out, but that will affect both front and rear brakes and sometimes it will force a leak.
- 1
From reading his ad, I think he is going to have a hard time selling it.
I would not pay that much for it but somebody just might.
There are better deals that come around.
If you have the plugs out, check compression in each cylinder
Noise!
Often referred to as a Can of Marbles sound at various rpm's
Quote
Needs cleaned and polished up still...
Nah! Just needs a new BlackBird home!
Very cool looking chain guard. If I didn't have a carbon fiber hugger/chain guard already I would pick it up myself.
Send Josh a PM and he will make arrangements
Perfect for the Giants in need!
Bill ?
- 1
You said bring it to a Dealer.
Unless you know that the tech is an A tech at the Dealer do NOT take it there.
Here in So Florida the best A tech's are not working at the dealerships.
Dealerships charge the highest shop rates as well. Ask around locally for a
reputable shop that works on a lot of sport bikes. Their rates will be cheaper
and chances are you will get better service performed.
It really should be a relatively easy thing to figure out with some multimeter
skills and the right wiring diagram.
You need to see if you have voltage at the fuel pump when the key is turned on.
If you have voltage at the pump then replace the fuel pump.
hooray! Great Job Sir
That I have, John, but I don't think we got together on price.
I will let him know you have one, he will be back home next week.
Joe,
Capt.Mike is also back looking for a Digital dash as well since the one from TN never arrived!
That is, when you go looking again in the near warmer future!
The connector is not the issue.
He has multiple wires that are all corroded up. He was looking to replace the whole harness itself due to finding so many wires badly corroded. He was opening up the harness and cutting back wires looking for good looking copper and stopped peeling back insulation at a foot log in multiple directions on multiple wires
Thanks, John, but I am going for the "de-link". I just got an email reply from a guy at Moto-Heaven.com that knows the lengths, but is going to use HEL lines. $98 shipped.
Cool, great price!
Jon,
It will take a little time but I happen to have a complete linked brake system that I took off a 2000 bike that I parted out a few months ago.
The complete Bird system has about 8-10 lines I think. I can measure up what ever you need.
They are Not proprietary and are readily available online
He is currently going through the harness wire by wire and will be replacing any and all bad (corroded) wires as needed.
No worries Vern, thank you for the first shot at it, wish I had been in a position to take you up on the offer.
I sold the harness from the 2000 that I parted out.
His current harness is full of corrosion. he started stripping back in all directions and stopped at a foot on multiple wires so gave up and decided to buy a new main harness from Honda but found out they are no more. He may end up doing a complete rewire himself but looking for a useable replacement instead.
According to Honda it has to be a 1999 or 2000 harness to work(same part number). In 2001 the Bird went digital so don't know if a 2001-2003 digital harness will work.
Big and Tall Gear Sale
Some monster man from Wisconsin needs a set of leathers fit for a giant.
He was forced to safety wire a set on for RacerXX !
