rhubarbray
Everything posted by rhubarbray
  1. I`d also recommend disconnecting the negative lead from the battery and hooking up a meter in series to measure amperage drain. Or milliamps. DON'T turn the key on, just do it with the key off. That will tell you if you have a component or wire going to ground. If you do have a short, pull and replace 1 fuse at a time until the meter drops to zero. That will tell you which system to start looking at.
  2. !! Damn!! Unfortunately, I`m already over my limit. 5 in the garage and rapidly running out of space.
  3. That,................is a lot of bike for $3k !! Sigh,......thinking about selling mine and wondering what I`ll get for it. Judging by this and other prices I`ve seen, not much. Phenomenal bike for next to nothing money !!
  4. What's the thread size? Did a quick search and there's an 18 and 20mm Helicoil but no 19. will also depend on how much meat is left around the threads. yow! Just did a search on the kits and they're nearly $180 for a kit!
  5. Can you get something like this in the correct thread? https://www.amazon.ca/Powerbuilt-640811-Back-Tap-Thread-Repair/dp/B0014FGVVW Goes into the hole past the damaged ones, picks up on good threads, expands, and then you back it out.
  6. Just checked MRCycles on their diagrams and they do show a changed p/n for the injected birds but still list a rotor with a completely different number ( 30291-MV9-671 ) for the carbed birds. Anyone have a pic of an early one for show and tell? Most of the carburetted rotors I`ve seen only have 4 lobes for a 4 cyl machine while the injected ones seem to have 10-16 lobes with a gap for cyl 1.
  7. Just about crapped when I saw this one, https://sfbay.craigslist.org/scz/mcy/d/1990-honda-vfr400-nc30/6349887739.html But they can ask anything they want.
  8. So how did the trip go?
  9. Hey, what you do on your vacations in Nigeria is entirely up to you and none of my business!!
  10. Never mind,..turns out it is a scam. Same owner has it listed all across the country and one guy actually posted a Craigslist ad warning. Wife of owner is out of state, use Ebay ecscrow to hold funds, blah, blah, blah,................crap. Did a little more digging and wow!! Good ones are going for some serious coin!!
  11. If not, somebody jump on this !!! https://newyork.craigslist.org/mnh/mcy/d/1991-honda-vfr400r/6310528520.html
  12. Just checked MRCycles, they`re $99 new.
  13. I`ve recently needed a dual 87 output relay, (no 87a) for the Ducati and found this place is about the easiest to search for what I need. http://www.rallylights.com/all/relays/l/diode/12-volts
  14. I just had a custom shock made by Jamie Daugherty of Daugherty Motorsports http://daughertymotorsports.com/cbr1100xx.html . It started life as a VFR800 shock then he added a custom piston and revalved, and resprung it for my weight. No core required if prearranged. I think it was less than $400 and wow! Big difference. I`m not a fast rider but enjoy pushing my own comfort limits and having fun in the twisties. I adjusted the rebound damping once and haven`t touched it since. The harshness over sharp bumps is gone.
  15. Btw....valve adjustments require an engine drop. Woot. !! Seriously?? Crap. And I thought the front wheel installation on a Honda CBX550 was dumb!
  16. Seriously? nobody has jumped on these? We already have a pair or these would be gone.
  17. that bike looks so much better than with blue wheels! I have an `07 blue dream.
  18. Damn!! If it wasn`t for the divorce that would follow VERY shortly after,.............damn!
  19. And we have a winner!! And the answer is,....................scam.
  20. Anyone care to take a look? http://houston.craigslist.org/mcy/5122417441.html
  21. Looks like Canadian XX blue
  22. I had never done any break-in on brake systems before but I`ll be doing it from now on. And actually, I had read the document but when I went out to do it, I forgot about the whole second set of braking and cool-down excercises. So my greatly improved brakes were from an unintentional half break-in.
  23. This. http://www.stoptech.com/technical-support/technical-white-papers/bed-in-theory-definitions-and-procedures/stock-brake-system-bed-in
  24. I just replaced the rotors and pads on my Subaru Legacy with StopTech brake parts. Thrilled with the results. Subaru wants about $100/rotor and then pads on top of that. I replaced everything for $279 with StopTech. But I think the big issue for me is I followed their break-in procedure after install. When doing the break-in I could feel the brakes getting stronger and stronger. Currently they are much stronger than the OEM ones when I got the car and I opted for the plain Jane no frills rotors. Their line of parts is called Centric and you will have a wide line of choices from which to choose. Plain, cryo`d, slotted, drilled, slotted and drilled, oversize, etc. Pick what suits you. I didn`t want super grabby brakes, just effective, quiet ones that won`t wear out in 10K. So far I got that and plus.
