Posts posted by ptxyz
the jt front sprocket that was on my blackbird when i had the chain break a few months ago had more play on the splines (in and out from the bike centerline) than i'd ever seen on any of my bikes.
i'd avoid any of their products.
sorry i didn't read this sooner.
you can, by removing the 3 or so bolts and 1 plastic push pin closest, leaving the rest.
it's a bit of a stretch (of that lower) but, it's a good idea to remove and clean the clutch push-rod too.
On 10/30/2019 at 1:53 PM, SwampNut said:
I might be more inclined to tell them about the chain and sprocket, and all the time, as well as potential future problems, and ask how they suggest they make up for it. Or possibly suggest that they just send me extra parts (more chains and sprockets) which costs them much less than cash. And in most companies, and employee can just send you parts on their own accord (or at least, I've had that happen a few times).
good suggestion, companies are loathe to dispense cash...
while i'll never put another of their chains on my bird, i might take one or two for my klr if i think that's all i can get from them...
small update, jt's asking for a dollar amount without saying they'll pay yet.
i'm figuring a full refund of the defective chain sprocket set to start ($179). i had to order a rear hub, ebay used ($29). i spent about 4 hours total repairing the case with epoxy (seems to be holding) and replacing the chain and sprockets. my time's worth something and even @ say $50/hr, way cheaper than a shop.
do you think $400-500's reasonable?
finally put the bird back together and went for a test ride yesterday. refitting the sprocket cover was fun, seems the bolt holes are not quite in the same place. i also needed to shave that thick metal "gasket" that's between the cover & case, it was touching the clutch pushrod. clutch action is, thankfully, smooth.
in one of my better recent moments of "i can't believe i fucking just did that...", i took out too many links to use my fancy 46 tooth supersprox rear... thankfully, the used ebay hub i bought (discovered the old chain damaged a couple of the sprocket mounting nuts / studs on it's way out) had a nice sunstar 45 tooth sprocket. i'll be back to stock gearing (17/45) for this chain...
still no word from jt on the failed chain. pressure will begin to be applied.
On 10/4/2019 at 4:14 PM, RXX said:
That looks like a nice place to work.
thanks! while downtown san jose has it's charms, like plenty of bars, restaurants and other entertainment venues, it's being overrun by the mentally ill and homeless.
there are also scenes like this on my way to work... was she trying to tell me i have a hot dog hanging out of my mouth?!
no progress on the blackbird last weekend. had to chase down a parasitic electrical draw (& replace a 6 year old battery) on our '98 e430. turned out to be another hvac blower motor resistor gone bad...
no word from jt regarding their inspection of the chain but, it only arrived to their lab friday...
ha ha! ok, now i get it! i could be accused of being an amateur reader and slow on the uptake too, just ask my wife!
jt has requested their chain back and tells me they want their lab to test it. stay tuned...
24 minutes ago, SwampNut said:
Amateur.
hey, i resemble that remark! seriously, that's why i'm here...
what would have been better to use?
carb cleaner in a spray can
i've cleaned and used jb weld to put that chunk back in place. chain and sprocket should be arriving this week (already have a new front, this one fits pretty tight unlike the last...).
also been in email communication with someone at jt. after seeing the marginal quality cell pics, same i've posted here, they'd like better pictures and details about the bike, install etc. hopefully, the lack of receipt on ebay purchases won't give them an out. it's promising they also want to see damage to the bike.
i'll keep y'all posted.
jcrich, your thoughts on the now 2 bolt sprocket cover? will they be enough?
just got a better look at the damage...
sorry, the rear sprocket damage is kinda blurry. you can see a gouge in the swingarm and one of the nuts.
marks from the chain on the sprocket cover's inside.
chunk where one of the cover bolts goes broke it's threads out...
does the community think the remaining 2 bolts will hold? don't see damage to the sprockets. i'm debating just getting a new good quality chain or should i replace the sprockets too?
if i go the later route, i'm thinking spring for a supersprox rear and oem front (17/47). this jt front has a bit more play than i'd like... -
had a close look at the rear sprocket, only damage i can see is from the chain getting caught up between it and the swingarm (locked my rear wheel, that was fun...).
sprockets and chain were replaced back in may, not sure of the exact mileage but, not more than a few thousand. one trip to laughlin and 20 mile round trip commutes (shared duty with my klr).
watched my gopro footage and don't see any debris on the pavement leading up to this. haven't yet noticed any missing fasteners or debris from me that might have caused this, i'll get a look at the front sprocket this weekend. i'm hoping i just have to replace the chain.
other side of the pin looks just like the visible side. appears to be a pretty clean shear.
so far, i'm inclined to believe it was the shock of regaining traction suddenly that caused a defective pin to fail. here's a screen grab from my gopro showing that slippery manhole cover... how fortunate work is only about 50-60 yards beyond!
"why the hell is that idiot pushing his bike down the sidewalk and through the crosswalk?!"
some fun on my way to work.after lane splitting through some tiny gaps (legal here), the blackbird was feeling frisky, having finally broken through to clear streets ahead. briskly accelerating, the rear wheel slipped a bit on a grated manhole cover and then found traction on the pavement beyond...acceleration abruptly ended, the motor rev'd and then the rear wheel locked up. i was in the middle of the #2 lane and the cars i'd just passed up must've been either cursing or laughing at me... actually, at least one of them recognized my predicament and sympathized "tough break"... after getting the chain free (my gloves will never be the same), i was able to roll the bike up a nearby (conveniently) driveway and onto the sidewalk and then the last block to work.i'll see if my ama membership or insurance towing will get me and the blackbird home this evening. as i recall, it's an rk chain and it's only got a few thousand miles on it.some may recall another motorcycle related (imagine that?!) thread i started regarding the sprocket combo i'm running;i've heard the 16 front sprocket can be harder on chains but, this caught me by surprise... while i feel rk owes me a chain, i don't think i want to risk another break. i'll get a closer look at things later and post up if i find anything else that may have contributed to this. coulda been much worse, i was only going 30-40. going home, i take the freeway!paul
had 'em get stuck in the schrader valve, causing a slow leak. i later found out there's a little filter to keep 'em outta there...
https://www.amazon.com/TyreBeads-Tire-Balancing-Beads-Filtered/dp/B00LTCL0H0
i'll stick with weights...
sold locally for $400. apologies to swampnut, the buyer wanted the pc2.
guy has 2 incomplete bikes now and intends to build 1. he also has a bunch of parts including some nice oem bodywork. pm me if you'd like his email, he's looking to sell / trade some of his hoard (lots of bicycles & tools too).
- 1
i have one similar to this i purchased used for $35. had my klr on it for several days while the forks were serviced and was able to drag it around the garage without issue. i did have 4 tie downs to stabilize things. only works with bikes that have frame tubes below the motor though...
then there's that other expensive one that uses the frame. i seem to remember them being more expensive that the ones here;
at this point, i'm still trying to sell the whole enchilada but, it's not clear how much of a draw these aftermarket bits are... not sure i want to deal with selling all the bits separate. one guy wanted the wheels, i do have some bent spares but, the front won't hold air anymore. image what a pain in the ass it could become to move...
i have no idea on the state of tune. bike had stock headers with yoshi carbon slip ons (these are now on my bike). haven't looked in the airbox.
one drawback to these is the need for a laptop with a serial port to access. i'm guessing this wouldn't be a problem for you.
i'll ask any potential buyers if they mind if i remove that. for you, i'd take $50.
would need; instrument cluster, battery, rectifier, front rotors / master cylinder & possibly bodywork not pictured (mirrors). wiring harness was partially disassembled by p.o. who planned a part-out. not sure if anything's missing, looks mostly there.
little bit of corrosion in the tank. no title, only a dmv printout showing no theft or liens.
still some farkles left; pc2, delinked brakes w/ steel lines, rear sets, remus cans (can provide stock if preferred). unknown clutch master cylinder (reservoir mount tab cracked off).
$500 / offer. open to trades for a truck or dual sportish bike or utilitarian car (wagon?). i know i'd need to throw in a grand or two to make that fair. also open to partial trades for blackbird parts, most interested in red bodywork or a full exhaust.
i bought this a year or so ago and got all the parts i'd wanted. now's the time to get it oughta here.
got these installed yesterday. found the low pressure 1/4" hose was in need of replacement, it ripped while i was pulling it off the metal bodied fuel filter i'd been using to connect... probably coulda used the 90 degree on the high pressure side was well.
very high quality, hefty parts. i'd imagine one could easily break a window.
replaced the cam chain tensioner and fuel pressure regulator "while i was in there", bike's running more smoothly and quietly now.
intended to check / clean the wax unit but, started to strip one of the screws trying to remove the darn thing... decided to leave well enough alone and go for a test ride.
+ another on the angel gt's, i'd recommend the a-spec unless you're scuffin' your knee sliders.
i have a 5/16" straight and 1/4" 90 degree (straight no available) on order from that link, i'll update once they're installed.
excellent & prompt customer service through the site.
thanks very much for that link and the detailed write up. i'm inquiring with these guys 1st;
https://www.beemerboneyard.com/fuliqudise.html
i see what i need in 2 different kits there but, will see if they can substitute a 1/4" straight connector for the 5/16".
it's somewhat ironic that the low pressure return line is the one that failed...
broke my 1st chain today!
finally have resolution to this. not exactly what i'd asked for but, i'm satisfied, given the damage was minimal.
jt rep. i'd been in email communication with asked that i call this morning. from the gist of it, they're unable to determine the exact cause of failure. they found no problems with the rest of the chain and suspect some problem with the single pin that sheared.
jt will pay me $250 and a future chain / sprocket set. i'll use that set on my klr650 or new to me xt225. no more less that top tier drive products for the blackbird.
i've never been too picky about my chains. cheapest i've used was a $50 volar that lasted all of 3-4k miles before stretching to the limit of adjustment. never expected this type of failure. i'm now more careful of situations where the rear might regain traction abruptly (like slippery manhole covers and dry pavement). not sure if i could've reacted quickly enough to the sudden loss of drive and increase in revs that accompanied this failure and prevented the damage to the lower engine case but, it's something i'll always think about going forward.
hope this helps someone else avoid this whole hairball...
