Posts posted by ptxyz
On 3/18/2021 at 11:20 AM, CBR-RR-XX-CESS said:
I have the same mounted, curious what the fee for a refresh is?
i had mine done a few months ago, was a bit under $300. besides the usual stuff, the shop recovered the lines to the remote reservoirs.
i like the analog dash but, always thought the tach should be front & center...
to the o.p., that's becoming an increasingly tall order and i'd expect to pay at least $5k. try https://www.searchtempest.com/
installed this yesterday. i noticed the rubber stopper had gone missing and a bit of chain wear on one of the center stand "feet" (no visible wear to the chain).
easy install (uses the right side sidestand bolt) and easy to adjust. i hear there're still several left.
i'd recommend this, even if you're running pipes with the rubber stop.
i'll take it!
pm incoming
thought i'd shared here before but, perhaps i'm not good at searching...
someone on another bird forum with less nudity and less probability of offense will be making more soon;
https://www.cbrxx.com/threads/centerstand-stop.50226/#post-645962
useful for aftermarket exhausts that lack or have substandard center stand stops.
one wonders why i still frequent this place... oh yeah, the nudity probability of being offended! 🤪
i'm with you, zero. return it to service. one shouldn't be under anything supported by only a jack anyway...
sounds like yours might just need to be refilled and bled.
guy has a bunch of how to videos.
this ebay listing gives the impression they could make you triple clamps (yoke) to fit most any type of usd forks;
think you just confirmed what furbird and ironmike were on to.
if it were just loose, you might be able to tighten. that little notch you're feeling is a dent worn into the bearing race with the steering at "dead ahead".
mind sharing the particulars as far as size of the house and cost of materials / installation?
here in california, cities are starting to make new construction go the other way (aka electrification). i believe berkeley now requires new construction to be all electric.
if you're home to hear it, how about a wireless doorbell?
https://www.amazon.com/wireless-doorbell/s?k=wireless+doorbell
beyond my abilities but, couldn't something like that trigger a landline call or some other type of notification if you're not home with her?
- 1
member of another forum is going to make a run of these;
https://www.cbrxx.com/threads/centerstand-stop.50226/#post-644458
- 1
no skin in the game. i'm 15 minutes away;
https://sfbay.craigslist.org/sby/mcy/d/morgan-hill-honda-cbr1100xx-blackbird/7140896171.html
+1 on the h.f. systems. i have the wired one with 6 cameras. i installed the wireless one at my dad's place. pretty easy to setup and use, although i haven't yet connected either to the web, i'm ok with just local storage. with the 6 cameras on motion only recording, i can store about a month.
resolution could be better, 1080p isn't always enough to read plates.
i've seen 238 fahrenheit (114c) on a very hot day in slow detour traffic. i hear the ecu will shut down the party at 250f.
be sure your radiator fins are in decent shape and the inside's free of scale, new thermostat's good insurance. you can also see a few degrees of cooling by reving the motor up to a few thousand rpms. a few here have added another cooling fan. i'd want to know they don't take up all your charging voltage at idle...
what you're seeing sounds pretty normal though. as has been noticed, these bikes run hot without airflow.
+1 on a 16t front to increase low end acceleration. rears are 44 or 45t.
besides a supersprox, i was unable to find other sizes for the rear.
having been in this neighborhood last week trying to fit an led bulb, can you enlighten me as to how you accessed the lower 2 bolts of the cluster?
On 3/14/2020 at 6:53 AM, RXX said:
Get him to post up and let us watch his progress so we can live vicariously through him.
i wouldn't expect too much for that poor old bike. guy's kind of a hoarder. he used to have a bicycle shop and the backyard's stuffed to the gills with the remains and overgrown with blackberry. front yard's got several bikes and a couple of project cars. nice neighborhood but, i'd bet the neighbors hate how his place (lives with mom) looks.
what are you doing with that yoshi system?
i have the take-offs from my '01 (with cats), as i recall they're in good shape but, they've been languishing in my he-shed...
i'm located in san jose.
finally made the time to install a rick's stator today. no drama other than tearing one of the stock plastic harness ties. 14.4 volts at idle, yay!
now for a test ride, 1st time in almost a month!
- 2
- 1
ebay seller will be getting a return, they paid shipping.
i ordered another from the rick's website.
will be nice to start riding the bird again. guess californy's about done for rain this season...
- 1
sold but, pm'd you the buyers contact info.
the brand is motoplat, i paid $100.
electrosport has a test for rectifiers here;
https://www.electrosport.com/pages/technical-resources
both the one in the bike and a used known working one tested ok.
this is my second stator failure, although not on the same bird.
i've asked the seller what they think. if they'll still accept a return if i install and find it doesn't work, i'm tempted to try. i installed a cheap ($35'ish) caltric stator on my klr several months ago and have had no issues. then again, my recent chain saga...
starter sounded slower than normal. checked with my voltmeter and read just over 12 volts while running at the newish battery. only 10-15 volts at the stator while running. the rectifier (& a spare) passed the diode testing.
i received this from an ebay seller yesterday and noticed a flake of the green epoxy in the bag as i opened it;
22 Year Old bird with a leak - radiator?
on a previous bird, the inner part of the fairing had been rubbing on one of the side tanks, making a pin hole over time...
i ended up soldering that but, i bet jb weld would've worked too.
+1 for repair or replacement with a cheap ebay unit.
