TuffguyF4i
Posts posted by TuffguyF4i
They suck. I have had two in a row fail under 6 months.
Thanks guys, this gives me more hope that it's just the weak battery. I check the charge level and CCA on all batteries before installing and note the CCA after a few cycles then monitor from there. I have too many batteries in use to ignore them and get stuck with another avoidable expense.
Buy a neverstart at Walmart. Charge overnight. Try it in the morning.
Regardless of outcome, return the neverstart.
ALWAYS assume it is the battery until you can prove differently. I have spent many a night wasting time troubleshooting when all I needed was a new battery.
...except one time when I had loose battery terminals.
I rest the rear wheel on my foot to get it into position.
No plug and play LED bulb is going to have the same output as an HID projector or even HID PNP.
Look at the stock LED headlight configurations in the new cars these days. Take the Denali or the Acura MDX or the new Audi...they all have multiple LED emitters behind very high end lenses. Anything less and you aren't getting light on the road any where near an HID.
A painted aluminum frame will get you nothing for scrap. Dirty aluminum is like $.10/lb.
Demand overnight shipping on a replacement.
Your two paragraphs contradict each other. Yes, there is relief valve but it only regulates maximum pressure. I don`t think you understand how lubricating system works, it is kind of open, oil from various parts of the engine drips down to the oil an where it starts its journey again.You guys know that oil viscosity is supposed to change, as the engine warms? 10W40 will vary somewhere between 10 and 40. And as it gets chewed up by motorcycle gears, 5 and maybe as low as 20.
Dave. I think your oil pressure will stay very close to the same PSI even as it degrades. For all practical purposes, it is a closed loop system and the pump sustains the needed pressure unless something is very wrong.
In the nutcase pressure at given point of lubrication system in the engine depends on rpm and viscosity. So different oil can give varied pressure readings all other things being equal.
I have a high quality aftermarket oil pressure gauge in my rx7. I had a fairy large and thick (3.5 ich) intercooler blocking somewhat the airflow to the oil cooler. I have since re- engineered my radiator/intercooler/ac/oil cooler arrangement so it now get unobstructed flow of air.
The oil pressure for given driving conditions went up by 20-25 % . Why ? Because the oil temps went down and consequently viscosity went up.
Where are you measuring that pressure? At the pump?
I'm sure as oil cools and viscosity increases the pump is doing more work and it has more resistance against the pump. You will also be picking up resistance through the entire system.
Thanks for the info. Always happy to learn more.
No thanks. I'm using an old street helmet now.
Edited..thanks.
I see no reason for to change from rotella full syn.
- 1
Zero is right,, the PSI for healthy engine wear is likely a wide range.
Picked up a dirt bike. I have no gear and i'm not about to drop $1k on new stuff.
I'm not picky on brand as long as it is a mainstream one. Not picky on color as long as it doesn't clash hugely with yellow.
I wear 9.5-10 for boots and Large for helmet.
My workouts are very simple and effective.
Only 3 sets per exercise and 2 exercises per group.
Day 1:
Chest
Back
Day 2:
Legs
shoulders
Day 3:
Arms
Conditioning
Make offer or trade for something I might like.
- 1
I assume he means trickle charger.
The clip ons are above the triple tree...so better for a taller person than a gsxr or the like. I'm only 5'10" so I fit on them all.
Not for me. I like a low rumble and it to wake up and sing at 6k+.
He didnt contact me, so I think he might just be messing around.
Now i know Dave has something kicking around worth trading! LOL
Got anything to trade?
I'm not selling for the cash, but only because i just can't justify having more than 2 bikes right now. Course, that doesn't mean i'm going to give it away. Just like everyone, i work hard for the money.
Michelin Pilot Power 3 rear tire-strange wear with a ridge forming.
It looks like the transition between hard and soft compounds.
