2equis
Everything posted by 2equis
  1. Dayum!!! Stealers SUCK!!!!!! Bearing and seal kit probably costs them under 20 bucks. It's about a 10 minute job to replace 'em (you did all the hard work for them already). Finding this thread a little late but you coulda just tapped the old bearings out from behind with a punch. The new bearings get tapped in with a rubber mallet and a socket the same diameter as the outside of the bearing. ...cake! sorry I didn't chime in sooner.
  2. I just replaced the wheel bearings on the dirt bike, they were TOTALLY fucked. No wonder the front end kept washing out in the sand. Anyway, anyone have to replace wheel bearings on the XX yet? I "wiggle" test the wheels whenever the bike is up on jacks, so far so good. I just hit 25k on the XX, I'm thinking about replacing them just for preventive maintenance.
  3. Yeah...That sounds like good ol' Klaus. Nagged the shit out of him to get my shock before Hookers last year, guy acted like he was doing me a favor.
  4. Most - It takes a really deep sump to keep any bike from running dry during an extended wheelie.
  5. Had the same problem so I ordered one of these....... from here........ Custom Dynamics Works like a champ, it does get warm so I ended up zip tying it to the subframe away from any wires.
  6. As promised, here is a new (advanced) 3-day per week program. It's something I developed a few years back via independent research and is based off of 3 important topics in strength and muscle development: periodization, evolutionary fitness, and holistics. This approach is quite different than what is commonly preached, and may strike some as odd. The most obvious difference is that, even though you hit a muscle group once a week, you only use that exact pathway once a month. For instance, you will do a bench press one week, an incline press the next week, a decline press the following week, etc. All of these lifts train the pecs, tris, and deltoids, but do it from different angles and, thus, use different portions of those muscles. This provides the best overall development and strength, but gives the muscle (specific pathway) a chance at maximal recovery. This is the basis behind "periodization", which avoids overtraining and helps prevent those nasty plateaus that most people suffer from when seriously involved in a weight program. (I haven't hit a significant plateau in 5+ years) Keep in mind that the days are not set in stone. If you can't train on mon, wed, and fri, then feel free to vary the days. In fact, "randomization" can be your friend. You know, one week you train on mon, wed, fri - the next week you train on tue, thu, and sat. It's all about keeping your body guessing so you can defeat its natural homeo-stasis. This is the basis behind "evolutionary fitness" Another difference: you will do the lift in a "holistic" way. After a brief warm-up (that may involve stretching), you do an 85% work set, take a break, a 75% work set, take a break, and a 45% work set. This scheme targets the fast twitch, medium twitch, and slow twitch fibers, which provides stimulus for the entire muscle. This provides maximum development and, thus, also protects against injury. One thing I like to do is "cycle". For instance, I'll do the 85% work set for one lift, and while that muscle is resting, I'll do the 85% work set for another lift. While resting from the second lift, I'll go back for the 70% work set of the first lift, etc. Cycling between pairs of lifts is an excellent way to keep your gym time short and allow for proper inter-set resting. Try to do the lifts in the order provided as much as possible. I've structured them so that the heavier "compound lifts" are performed first (they are the most important). After compound movements come "isolation movements", which require less energy and are easier to complish after a certain amount of fatigue has set in. You'll see what I mean if you reverse the order - the compounds are hard to do when tired.. The most important thing to do is to perform each lift with the strictest of forms. If not, you risk injury. I've studied exercise kineseology for quite a while now, so I can give anyone advice on how to perform these exercises. If you have difficulty performing a lift, shoot me an e-mail and I will try to explain or even point you to an equivalent you can use as a substitute. The same goes for the equipment you use. It doesn't matter whether you use free weights or machines (though machines are safer for a solo lifter). The most important thing is the "improvement" that you try to make each week. Give 100% to try to get atleast 1 extra rep for each set of each lift each time out. If you can go up 3-4 reps, then add about 5% to the weight and go back to the original rep count. For example, if you start out doing 6 bench presses in your 85% workset at 100 lbs. and you manage to get to 9 reps -- then increase the weight to 105 lbs and drop back to 6 reps. This is another type of periodization, and you should be able to make consistent progress with this scheme. However, if you can't, don't panic. If you get stuck in a plateu or go backwards, then you may be overtrained. Relax, and don't panic. Just stop the set and give that muscle group extra rest for the next time out. Rest is important, and when you are not in the gym, do your best to rest, relax and de- stress. (try to get to bed early too!) After lifting, you're done for the day. The best way to make consistent gains, aid in recovery, and kill any sweet tooth you may have while low carbing is to do a "post-workout" shake. I've mentioned this before. It's basically 1 cup of grape juice mixed with 1 cup of water and 1 serving of egg protein powder (or other protein supplement). Mix up the stuff and take it with you. As soon as you're done with the lifts, gulp it down and go and hop on an exercycle and pedal SLOWLY to warm down. After 10-15 minutes of cooldown, hop off the bike and head home. Avoid eating dinner for atleast 45 mins after taking the shake in the gym. This will allow your body to uptake the glucose into the muscle more effectively - aiding in recovery, almost like a steroid.. It also helps kill any sugar cravings, atleast in me.. So, without further ado (with example logging notation imbedded): *************************************** WEEK #1 *************************************** LOWER BODY(MON) UPPER BODY(WED) MIDSECTION(FRI) *************** *************** *************** Dumbbell Deadlift Overhead Press Bent Over Row ----------------- -------------- ------------- 10 @ 50% warm-up 10 @ 50% warm-up 10 @ 50% warm-up 8 @ 85% +1 | +5 lb. 6 @ 85% | 6 @ 85% -1 | + 15 lb. 12 @ 70% | 12 @ 70% | 12 @ 70% | 24 @ 45% | 24 @ 45% | 24 @ 45% | Single Leg Extension Standing Machine Shrug Rotary Curl -------------------- ---------------------- ----------- 10 @ 50% warm-up 10 @ 50% warm-up 10 @ 50% warm-up 8 @ 85% | 10 @ 85% | 6 @ 85% | 16 @ 70% | 20 @ 70% | 12 @ 70% | 32 @ 45% | 40 @ 45% | 24 @ 45% | Lying Leg Curl Decline Flyes Twisting Crunch -------------- ------------- --------------- 10 @ 50% warm-up 10 @ 50% warm-up 10 @ 0 warm-up 8 @ 85% | 6 @ 85% | 20 @ 0 | 16 @ 70% | 12 @ 70% +2 | +10 lb. 20 @ 0 | 32 @ 45% | 24 @ 45% | Seated Calf Raise Triceps Extension Reverse Wrist Curl ----------------- ----------------- ------------------ 10 @ 50% warm-up 10 @ 50% warm-up 10 @ 50% warm-up 15 @ 85% | 6 @ 85% | 12 @ 85% | 25 @ 70% | 12 @ 70% | 24 @ 70% | 35 @ 45% | 24 @ 45% | 48 @ 45% | Hip Adduction Front Raises Lat Bar Pullover ------------- ------------ ---------------- 10 @ 50% warm-up 10 @ 50% warm-up 10 @ 50% warm-up 16 @ 85% | 6 @ 85% | 6 @ 85% | 24 @ 70% | 12 @ 70% | 12 @ 70% | 48 @ 45% | 24 @ 45% | 24 @ 45% | *************************************** WEEK #2 *************************************** LOWER BODY(MON) UPPER BODY(WED) MIDSECTION(FRI) *************** *************** *************** Leg Press Incline Press Front Pulldowns --------- ------------- --------------- 10 @ 50% warm-up 10 @ 50% warm-up 10 @ 50% warm-up 8 @ 85% | 6 @ 85% | 6 @ 85% -1 | + 15 lb. 16 @ 70% | 12 @ 70% | 12 @ 70% | 32 @ 45% | 24 @ 45% | 24 @ 45% | Back Raise Dumbbell Shrug Preacher Curl ---------- -------------- ------------- 10 @ 50% warm-up 10 @ 50% warm-up 10 @ 50% warm-up 30 @ 0 +1 | 10 @ 85% | 6 @ 85% | 20 @ 0 | 20 @ 70% | 12 @ 70% | 40 @ 45% | 24 @ 45% | Lying Single Leg Curl Crossover Cable Flyes Incline Situp --------------------- --------------------- ------------- 10 @ 50% warm-up 10 @ 50% warm-up 10 @ 0 warm-up 8 @ 85% | 10 @ 85% | 20 @ 85% | 16 @ 70% | 15 @ 70% +2 | +10 lb. 20 @ 70% | 32 @ 45% | 25 @ 45% | Rotary Calf Raise French Press Barbell Wrist Curl ----------------- ------------ ------------------ 10 @ 50% warm-up 10 @ 50% warm-up 10 @ 50% warm-up 12 @ 85% +1 | +5 lb. 6 @ 85% | 12 @ 85% | 24 @ 70% | 12 @ 70% | 24 @ 70% | 48 @ 45% | 24 @ 45% | 48 @ 45% | Side Bend Lateral Raises Dumbbell Pullover --------- -------------- ----------------- 10 @ 50% warm-up 10 @ 50% warm-up 10 @ 50% warm-up 24 @ 70% | 6 @ 85% | 6 @ 85% | 20 @ 70% | 12 @ 70% | 12 @ 70% | 24 @ 45% | 24 @ 45% | *************************************** WEEK #3 *************************************** LOWER BODY(MON) UPPER BODY(WED) MIDSECTION(FRI) *************** *************** *************** Barbell Deadlift Decline Chest Press Lat Pulldown ---------------- ------------------- ------------ 10 @ 50% warm-up 10 @ 50% warm-up 10 @ 50% warm-up 8 @ 85% +1 | +5 lb. 6 @ 85% | 6 @ 85% | 16 @ 70% | 12 @ 70% | 12 @ 70% | 32 @ 45% | 24 @ 45% | 24 @ 45% | Leg Extension Seated Shrug Dumbbell Curl ------------- ------------ ------------- 10 @ 50% warm-up 10 @ 50% warm-up 10 @ 50% warm-up 8 @ 85% | 10 @ 85% | 6 @ 85% -1 | +15 lb. 16 @ 70% | 20 @ 70% | 12 @ 70% | 32 @ 45% | 40 @ 45% | 24 @ 45% | Seated Leg Curl One-arm Butterfly Machine Crunch --------------- ----------------- -------------- 10 @ 50% warm-up 10 @ 50% warm-up 10 @ 50% warm-up 8 @ 85% | 6 @ 85% | 20 @ 85% | 16 @ 70% | 12 @ 70% +2 | +10 lb. 20 @ 70% | 32 @ 45% | 24 @ 45% | 40 @ 45% | Standing Calf Raise Rope Pulldown Hammer Curl ------------------- ------------- ----------- 10 @ 50% warm-up 10 @ 50% warm-up 10 @ 50% warm-up 8 @ 85% | 6 @ 85% | 6 @ 85% | 16 @ 70% | 12 @ 70% | 12 @ 70% | 32 @ 45% | 24 @ 45% | 24 @ 45% | Rotary Torso Reverse Flyes Radial/Ulnar Flex/Extension ------------ ------------- -------------------- 10 @ 50% warm-up 10 @ 50% warm-up 10 @ 50% warm-up 16 @ 70% | 6 @ 85% | 25 @ 85% | 32 @ 45% | 12 @ 70% | 25 @ 70% | 24 @ 45% | *************************************** WEEK #4 *************************************** LOWER BODY(MON) UPPER BODY(WED) MIDSECTION(FRI) *************** *************** *************** Hack Squat Bench Press Chin-up Pulldowns ---------- ----------- ----------------- 10 @ 50% warm-up 10 @ 50% warm-up 10 @ 50% warm-up 8 @ 85% | 6 @ 85% | 6 @ 85% -1 | + 15 lb. 16 @ 70% | 12 @ 70% | 12 @ 70% | 32 @ 45% | 24 @ 45% | 24 @ 45% | Back Raise Barbell Shrug Cable Curl ---------- ------------- ---------- 10 @ 50% warm-up 10 @ 50% warm-up 10 @ 50% warm-up 30 @ 0 +1 | 10 @ 85% | 6 @ 85% | 20 @ 0 | 20 @ 70% | 12 @ 70% | 40 @ 45% | 24 @ 45% | Kneeling Leg Curl Seated Butterfly Leg Raise ----------------- ---------------- --------- 10 @ 50% warm-up 10 @ 50% warm-up 10 @ 0 warm-up 8 @ 85% | 6 @ 85% | 20 @ 0 | 16 @ 70% | 12 @ 70% +2 | +10 lb. 15 @ 0 | 32 @ 45% | 24 @ 45% | Incline Calf Raise Triceps Press Barbell Reverse Curl ------------------ ------------- -------------------- 10 @ 50% warm-up 10 @ 50% warm-up 10 @ 50% warm-up 16 @ 85% | 6 @ 85% | 12 @ 85% | 24 @ 70% | 12 @ 70% | 24 @ 70% | 48 @ 45% | 24 @ 45% | 48 @ 45% | Hip Abduction Upright Row Seated Row ------------- ------------ ---------- 10 @ 50% warm-up 10 @ 50% warm-up 10 @ 50% warm-up 15 @ 70% +1 | +5 lb. 6 @ 85% | 6 @ 85% | 25 @ 70% | 12 @ 70% | 12 @ 70% | 35 @ 45% | 24 @ 45% | 24 @ 45% | Quick explanation of notation: 15 @ 70% +1 | +5 lb. - Means 15 reps at 70% of maximum weight (1RM), - an actual weight should be written into your log, not a percentage - +1 means that you were able to get one extra rep the last time out (modifier) - +5 means that you are currently lifting 5 lbs heavier than baseline (modifier)
  7. I say yes... use them. You'll save yourself from all sorts of expensive repair bills later on. I use one when I ride almost ALL of the time. I haven't seen any real performance loss by using one either. :wink:
  8. Only 4-5 lbs :? But my BMI is down 4-5% which is more important
  9. Going back to 96-97 ish I read in some moto mag that the original XX front brake lever had to be re-designed because at high speed it actually created enough drag that it would sometimes trip the brake light switch. NOT apply the brakes.
  10. Read the same thing way back when. Order the shortys, There is no way the wind would have the leverage to apply the brake.
  11. Not to hijack but I almost wrecked the first time I ever used a throttle rocker. If anyone is considering buying one.....STAY AWAY!!! :shock: http://www.throttlerocker.com/info.html
  12. +1
  13. Whadda ya mean... drain the oil? :?
  14. Reminds me of the line from Bruce Almighty - "I'm on the Krispy Kreme diet and I've lost 40 pounds" Maybe I'll try the Stillmans diet, I think I need something to kick start my metabolism. I'm at the gym 5 times a week (3x cardio and 2x weights) and my BMI hasn't budged. If that doesn't work maybe I'll try the "eightball" diet. :twisted:
  15. Sounds kinda harsh :?
  16. My SMX's broke in at the ankle, the rest of the boot should still stay stiff. They are (race boots) alot different than than sport touring boots. My sport touring boots broke in like slippers.
  17. If you find them let me know...Spark City Baby!!! :twisted:
  18. 2equis
    520 chains
    If it was a track bike maybe, but running a 520 on a street XX doing all weather, cross country riding etc.. I'd stick to the added security of the 530.
  19. 2equis
    520 chains
    Cause DID only rates their 520VM chain to 750cc and I don't feel like fragging my crankcase :poke:
  20. Ping Hobicus about those.
  21. Maybe it's French :roll:
  22. But how do you keep oil from leaking out of the hole after you install the new filter like that? :roll: :wink:
  23. +2 Have any get-offs or driveway mishaps lately? I'd pull the tailcowl and inspect the subframe.
  24. Quit wackin' it!!! :wink: Nothing useful to add just chiming in.
  25. +10000!!!!!!!
