Posts posted by JoWhee
On 3/28/2022 at 7:02 PM, XXitanium said:
Air conditioning basically doesn't work till enough humidity is removed from the space being conditioned.
@JoWhee right?
EDIT: I wrote this before reading all the comments and OP. As someone who lives in the north I'm no stranger to dry and chapped skin itchy as fuck also. A good moisturizer is the easy solution. I'm not a fan of humidifying because of all the possible issues. mold, scale buildup in the unit, but if it's causing medical or for that matter computer issues, then obviously, humidify, just buy a good automatic unit.
Air conditioning is just a heat pump it's pumping heat from one place to another, as it's impossible to pump "cold" . The dehumidification is a byproduct of the cooler air being able to hold less water, causing the relative humidity to drop. Air temperature and humidity are related, google psychrometric chart if you're into that kind of detail (I'm NOT). It's probably why the same size A/C in Arizona might work better than the same one in mississippi, because the one in AZ isn't dealing with as much humidity and therefore less total heat assuming the temperature is the same and not 140 degrees. It's also the reason some idiot will say it's not the heat it's the humidity, because you feel it more when it's a damp heat.
- 1
21 hours ago, Zero Knievel said:
Did I actually just SOLVE a problem?
WOAH! Isn't this a sign of the end of times?
She felt it still wasn't enough and put an old photocell-activated night light by the door to the basement.
<facepalm>
Why the hell didn't I think of that? I literally have a motion detector in my garage hooked up to its own light. DOH!
Of course it was easy for me to do the install as it's an unheated detached garage, so running the wiring was pretty easy. The light comes on and stays on as long as there's motion, so as long as I'm not having a nap in there it's lit.
I'm thinking there's a delay timer inside the opener. It's probably on a circuit board (duh) but it should be easy to spot because it will have a relay for the 120V to the light bulb. As for reprogramming it, I"m sure it's possible, but it would be a hell of a job just for a light. Why not just hook a wifi switch into or onto the garage door opener. If it's on the top you won't see it or the wires. It won't be as elegant, but it sounds easier to me.
Unless it's a new superefficient unit you should be on Aux heat at 20 degrees. If you're getting heat don't worry about it. I;m not going to explain the parameters for when the AUX heat comes on, I'm sure there are more than a few long and boring articles about it via google.
On 1/10/2022 at 2:50 PM, XXitanium said:
Yeah, slave devices with a master board they hook into.
They don't ship as a consumer unit. You would need a control panel and an alarm horn and programming for additional money.
https://www.cdc.gov/mmwr/volumes/66/wr/mm6608a9.htm
I don't really see the need for a CO2 monitoring device for homes. But I guess there's a market for any gadget.
As for CO monitoring there are several consumer units Kidde makes most of them, I've got 2 that plug into a regular outlet in my home, they are as loud as a smoke detector. One of my hard wired smoke detectors is actually smoke and CO now that I think of it.
You're making this way too complicated. How expensive and durable is your radiator? Just wire the fan to come on at the same time as the pump, if you're worried about how much current the fan draws versus how much you you have available for the pump, use a a relay. Don't worry about the few btus of residual heat you'll have in the heater core, unless it's an old cast iron monster, it won't keep much heat after the furnace and pump shut off.
18 hours ago, SwampNut said:
Really? I've never seen one, and google doesn't find any.
I realize it was a typo on the part of Zero. However there are CO2 detectors. I can get you the brand once I'm back to work. Were using them in schools (yes for covid!) because CO2 is an indicator gas* of how much fresh air there is in the space. They're about the size of an iphone 3gs and twice as thick, wait... as a pack of american cigarettes.
*I'm sure there's another term for this, but it refers to indoor air quality.
I should also mention that my work is using them in old as fuck schools with little to no mechanical ventilation. Depending on PPM levels: it's either OK, Open window(s) and classroom door, leave space immediately.
The sensors monitor continuously but the display only reads out a 5 minute average. This is to prevent any fuckery by a bunch of kids blowing on it to get out of class. They are all iot devices, but I don't know enough about the network side of them if it's inter or intra net, I do know there is a bridge connected with a cable to the network switch to bring the info to, I presume, our building automation foreman. The school principals get a weekly summary.
Yes it's called an HRV, we use them in Canada, I'm not sure how popular they are stateside. It's also a decent solution for radon gas.
The HEPA is a decent addition for $150 especially if you have pets.
- 1
On 1/2/2022 at 1:34 PM, SwampNut said:
If there are good Canadian beers, they never make it past the border. I mean, compared to swill like Budweiser, everyday Canadian beer is great. But I have yet to find any exceptional Canadian beers and I've tried (compared to today's great microbrews and craft).
We keep the good ones to ourselves, sorry. (not sorry).
Anything mass produced is just like McDonalds, it will fill the hole and the crapper, but it's not satisfying.
On 12/31/2021 at 2:36 PM, tomek said:
On the other hand, beer is way more expensive and definitely behind US microbrews in quality.
I always bring my own beer when I go to Canada.
Illegally of course.🤐
For historical reference: This is how the Canada USA war started in 2022.
Just kidding, because you're talking about micro brew, it would be a war fought by hipsters. Seriously though, if you're ever in Canada around Montreal, hit me up, I'll get you a list of micro breweries that are worth the detour.There are some amazing micro brews on both sides of the border, but generally I avoid all brewery beers like molson coors etc.. The exception being Yuengling.
Q: What do american beer and making love in a canoe have in common?
A: It's fucking close to water.
- 1
Unethical LPT for Mc'd breakfast mcMuffin. This works 8/10 times for me when it's busy. I order a sausage mcmuffin, on the app. Receive a sausage mcmuffin with egg.
I'm admittedly a "trying to reform" junk food junkie. Mc'D is supposed to be almost the same all over the world, but even between the US and Canada there's a big difference, their meat is different and US chicken nuggets are gross and nothing like the ones in Canada. Maybe I should say more gross?
OH DROOL!
I once had a roommate (from France FWIW) who ate a plantain I was ripening. When I asked if he ate it he said "yes, it was fucking horrible, he could barely eat the whole thing!" He compared it to eating a raw potato. I don't know how he managed to finish it or not get sick, BLEECH!
PS MOFONGO!
What kind of roll you use is going to depend on what tools you're carrying? Basic daily tools for patching a flat, or the I'm-going-across-the-country-and-I-need-several-bike-specific-tools kind of kit?
Great price, and great comms, too bad they only fit certain helmets, I'm glad mine is one of them! Mine didn't come with JBL speakers so I bought a set as an upgrade, it's not audiophile quality but a noticeable difference.
GLWS
21 hours ago, jon haney said:
That's fine, but don't expect everyone else to wait for you. Make sure you know the whole route, and planned stops before hand, otherwise you might find yourself riding alone the whole day. For the record, I've never "got a knee down", even on the many track days I've done. Not flexible enough for that, apparently.
HOLD UP! aren't you a drag racer? A knee down would be a bad thing in that situation IMO.
- 1
3 hours ago, Zero Knievel said:
True, but there should be something “in between” that suits my needs. Do motorcycle tires have a longevity rating like car tires? Where can I find it?
I got 10K easily out of my Pilot Road 4. These Road 5 tires just aren’t holding up.I've heard the Angel GT's get great mileage, and are decent in the twisties. However, is it possible you're riding the BMW a little more aggressively that you did the bird? It would explain the increased tire wear.
Most of those tires are for touring rigs. Like gold wings, baggers etc… I’m not sure how happy you’d be with a set of 888's on your BMW. They wear like iron and are about as sticky.
- 1
1 minute ago, SoloTSi97 said:
It's not. If you recall, you helped me locate some plastics for it a few years ago through a Canadian dealership.
I remember that, but I thought they were the same colour.
The road 5 comes in a GT version, it is supposed to last a little longer. That being said I've never had a tire last 6500 miles, it must be my fat ass. My road 5 gt front was toast just under 6000miles, I'm lucky to get 5000 miles out of a rear. I run weights up front and balance beads in the rear, I've never had an issue or cupping of a tire until it was due for replacement.
Unfortunately, Michelin has discontinued the 5gt in my size, so I'll probably run a 5 until the front wears out then replace them with a set of Angel gt2, unless the Dunlop Mutant drops in price is in stock.
- 1
The involved part would be balancing the tire. The guys I ride with do their own and use balance beads front and rear. My tire guy can't use weights to balance my rear because he doesn't have the large hub adapter necessary. I'm running beads in the rear, 2 tires now with about 7500km on each. No unusual wear or cupping (no really the tire isn't cupped!). I got a flat in the second tire at about 1000km and patched it with a rope plug. The tire now has about 6000km on it and the plug is holding and the balance was never off due to beads sticking to the plug. I still have massive chicken strips though 😕
My tire guy(s) charges about $50 per wheel off the bike, I could borrow my friends tools for free, but for the price it's not worth it to me.
You may also want to check with local riding/racing groups on facebook, both my tire guys do track days so they have the machines and do the work for cash. They're done in less than 15 minutes whereas it would probably take me over an hour and a few skinned knuckles.
4 hours ago, SwampNut said:
Take the motor out and turn it upside down.
That's only for teslas, might as well do an oil change while you're at it.
Nice, I noticed your desired outcome will have no back seat, why the monoposto?
Either way: gorgeous.
FZ1 for sale in PA
Damn, now I need to add another bike to my list "post ducati" sale.
