BigMig
Posts posted by BigMig
Bump...let's say $200 ?
Philadelphia metro area - just in case that makes a diference.
Mike
For sale - Shoei X-11 sz L full face (of course) helmet. Downsizing stuff in the garage. Can ship in Conti US.
It does have small scratches in a couple places and the shield has a big scratch, so $225 seems fair. Vents work well and the liner, etc are in great shape. HAve a Shoei box that I can use to double box if shipping.
$225 and split shipping.
From their Website:
Excellent capillary action on initial application, which allows the product to penetrate the tightest of gaps.
After a few minutes the solvent evaporates leaving a highly adhesive, waterproof load bearing oil.
Splash-proof and saltwater proof. Also resistant against non-concentrated acids and alkalis.
Free from silicone, resin, and acid.
Here's the Amazon page on it: http://www.amazon.com/Wurth-HHS-2000-Penet...t/dp/B0002XRDLE
Evaproative base - seems good; doesn't attract crud = good, gets into tight places = good; -95F to +392 F = good; user says doesn't fling off = good.
Could this be better than the DuPont teflon dry spray?
Could you guesstimate how much of a temp difference this alum. radiator made in hot weather?
Thanks,
You guys ROCK. Thanks for all the GREAT INFO.
Mike
I watched a couple of Youtube videos about replacing a tire on a motorcycle...seems do-able - even for me. Seems that balancing might be trickier...and require a little finesse.
Anybody have pics of a home made setup for balancing? Special Method/Tricks?
Many thanks, bro. THat's just the ticket! Can't wait for them to arrive...then to find an installer.
Take care.
Your welcome. Just go buy a set of irons and do it yourself. Watch a few videos on the process first. I did my first set last year. It takes a while the first time, but it is worth the knowledge gained.
Videos? Do they also tell you about balancing, etc? Other stuff too?
Take care.
Ok guys - my '01 bird needs new tires. If I mail order Pilot Road 2s, should I be concerned that they're really old stock and the rubber may not be so pliable? Then, who's the best vendor for these Pilot Roads? I'll need em shipped to Phialdelphia area...FYI
Thanks,
I think they're great...lightweight, inexpensive and when you get creative, you can do a TON of exercises with them. This is esp good if your hotel has an inadequate exercise rm.
Mike
+1
Oh, and the PR3's are out now - and they are totally bad ass.
Just sayin.
PR3 - is that Pilot Road 3??? Reviews, etc? C'mon, hook a brother up!
Mike
Hey, team, I'm ready to order some new Pilot Road 2s for my 2000 xx. I've read posts talking of "touring and 2-up" tire sizes vs std which is 180/55-17. Can somebody clarify this for me? Benefits/drawbacks - cost differential (of course)? No change in the size of the front, correct (120/70-17 - right?)
Thanks,
Mike
I'm sure they'd work on a 97-03 XXs. Not sure how they compare to Heli's (in height) but in my opinion, they don't look "frankenstein" but instead, like the stock bars, just a bit higher, allowing the rider to sit a bit more upright...
Let me know who's interested.
Thanks.
Mike
I haven't received a PM.
Mike
shameless bump - haven't heard from "Dibs" poster...
Mike
Here's what I do when I need a chain:
1. Ride cycle to NEXXT with crappy chain on the bike (2008, I think)
2. Ask Hobie to supervise me and teach me to change the thing myself
3. Al (Toynut) gives me heavy rubber gloves, aluminum pan and a full can of Brakekleen to clean up parts that will go backl onto the bike
4. Hobie (Rich) pushes me out of the way and does the whole thing, allowing me to only clean up the wheel, and other parts.
5. I go on rides with the group, and notice that I no longer have the repetitive pull-and-slack of a worn out chain.
Wow, that was easy!
Way to go Rich and Al.
Thanks again guys!
Mike
PS - stick w DID X ring...and change the rear sprocket at least.
So, I'm in the process of installing grip heaters.
Where should I put the toggle switch for on/off/Hi vs low? If you have pics, I'd appreciate it.
Thanks, team.
Mike
Bump...and price reduction to $39, shipped to conti US.
Anybody? anybody???
Notes to self:
1. grow hair
2. buy hairspray
3. install XX grips
styling mouse? I'm hair challenged, bro!
Thanks, and thanks also to Al.
I ended up doing the hot water soak of the new grip, followed by a tiny amount of gorilla glue pn the dual star. Seems to be ok. Will know in the AM.
Mike
Team XX,
I'm attaching Dual Star heaters to my bars and I don't know what's the preferred adhesive to use to bind my new grips (BMW sport) to the barsw dual star heaters. I guess there's a chance I'll eventually want to change grips and not destroy the heaters. Maybe I shouldn't worry about that.
Any suggestions will be greatly appreciated.
Mike
You guys rock!
See? I KNEW you'd have better ideas than mine.
Many thanks.
Mike
The manual says to remove the coolant reservoir...I'm thinking I'll just siphon the reservoir and save the trouble of tank lift, etc. Then proceed w draining from water pump and head, etc
Anyone forsee probs with doing it this way? I've never taken the tank off before and am not too confident - and there seems to be an easy work-around.
Left Engine Cover Replacement
OK team, I FINALLY bought a left side engine cover and gasket for my 2000 XX. The existing one got rashed up a bit and I "patched" it with JB Weld - color was similar. But in truth, it looks like crap, and there has been a tiny oil leak - I suspect from this point.
So in looking at my new cover, there appears to be components that attach to the insode of the cover. Can anyone share a procedure to do this swap-out for a guy with modest mechanical experience? Also, since I have the gasket, is it recommneded to use any liquid gasket material, or just let the gasket "do its thing?"
Lastly, what about the place where the stator wires go into the cover - any "stuff" you recommend to apply there or will the rubber square that surrounds the wire group work well?
Thanks in advance
Mike (BigMig)
