XXMAN
Posts posted by XXMAN
I know nothing about water wetter but I do use engine ice. It comes premixed just pour it in. It is suppose to drop engine temps up to 50 degrees. My bike does seem to run cooler and I have never had a instant of coolant leaking.
I like my Givi. :grin:
Will 98 rims fit a 97?
1 ticket 2 warnings black XX
They are correct 27mm for nut and 22mm for axle. Happy wrenching.
I have a 98 and if I remember right the socket is 18mm for the nut and 23mm for the axel. someone correct me if i'm wrong. I will double check when I get off work and post it tonight if different. :bike:
I found this on Nascar web site. Most of the teams remove the air from the tires and replace it with nitrogen. Compressed nitrogen contains less moisture than compressed air. When the tire heats up, moisture in the tire vaporizes and expands, causing the pressure inside the tire to increase. Even small changes in tire pressure can noticeably affect the handling of the car. By using nitrogen instead of air, the teams have more control over how much the pressure will increase when the tires heat up. I was not able to talk to a mechanic at work they were to busy how ever the nitogen bottles use to fill aircraft tires are labeled compressed nitrogen un 1066. Hope this helps. :patriot:
I'll find out when I go to work saturday. :bike:
It is used in aircraft tires and planes are very heavy with high landing speeds. I don't think it would hurt but I'm not sure if it is worth the trouble. :cycle:
I think Involute has the set up your looking for ask him for more info. I believe he uses koss ear plugs but he has modified them. Hope this helps. :grin:
What do you do if it rains? Is it waterproof? :cycle:
I use engine ice works great. :patriot:
I won that auction for right cowling on ebay. My bike was damaged at Sturgis hit and run assholes. Cracked the fairing and the dash on right side. :evil: :50cal: :guns: :shoot: :twak: :chainsaw: :flame: Needless to say i'm a little hot under the collar.
signal
Turnsignal socket was bad thanks for all your guys help. $13.00-14.00 part if anyone cares Thanks again. :shoot:
signal
I was changing to silver bulbs because of clear turnsignal lens it was working fine pryor took bulb out an reistalled new ones worked fine used tape to stop running lights took one out and reinstalled and now turnsignal will not work checked connections in the faring they are all tight. :banghead:
signal
kept playing with bulb have running lights no signal tried different bulb still rapidly clicking no flash for turnsignal.
signal
Right turn signal quit working it clicks more rapid than normal no lights any ideas? :idea:
Grips
I like my Pro Grips model 719. My 2 cents :bike:
Only one hand am I doing it wrong :?:
I like my Dunlop 208's but I haven't had them long enough to discuss wear yet. I got a set of 208's shipped to my door for 195.00 I think that is a good deal. I got them from motorcycletireplanet.com. Hope this helps. :headscratch:
parts
Custom wheels were on the bike when I bought it I'm not sure what make they are to be honest I haven't looked to see. Ill have to look now im curious. :cycle:
parts
I have a 1998 cbr 1100xx with custom wheels,seat,handlebars and windshield. My question is should I keep the stock parts that are not being used or sell them any thoughts :?: :banghead:
I have AT&T broadband and AOL. AT&T works and AOL does not. I think your right about AOL being the problem.
Collett electronics sells mini blasters for 29.99 there probably the same speakers being sold at aerostich. I don't know if there is any difference in the price. I had purchased a communicator from Collett with these speakers and they work great as for the communicator :sad: not happy. Hope this helps.
Getting some nasty headshake.
Could it be worn head bearings?
