XXMAN
Posts posted by XXMAN
If your bike sounds likes it has marbles in the engine on startup when it's cold then it warms up and go's away this is normal.
test
I complained to my cable company that one of my tv's didn't work like it should. They came out and checked the signal and said it was too low. Then they upped the signal no problems now cost me nothing.
Would not a pressure washer do this job 3000 to 4000 psi. I was told 3000 psi will strip paint.
Problem solved replaced new cap with another new cap.
Brand new radiator brand new cap
Thermostat has been replaced still same problem upper hose gets red hot while bottom is just warm the water is definitely not circulating. Water pump and head gasket were replaced I think two years ago. It seems like the water is not making it to the sensor so the gauge is not showing it being hot. It also has a new radiator like a month old. Thanks for everyones help I really appreciate it. I guessing water pump as the best bet at this point.
I think the water pump is shot.
temp gauge is never above halfway
I know it's probably too late now but you must rent a power scraper for an easier job don't ask me how I know.
I HAVE A 1995 HONDA CIVIC EX 1.6 VTECH ENGINE FILLS OVER FLOW BOTTLE WHEN IT GETS HOT AND OVERFLOW BOILS OUT ALL THE ANTIFREEZE ANY IDEA HOW TO FIX THIS PROBLEM.
TINT
Has anybody ever tried to tint their shield on their helmet with colored spray tint?
I always regrease my axel before reinstallion more lube is good if you ask me.
Her hips but it doesn't seem to help much with vibration.
Newbie
Welcome and try looking at for sale section I believe there is at least one corbin for sale at this time.
Lockhart Phillips here. Relatively cheap, good fit, and no damage to the underlying paint after 40k+ miles (went through two bras in that time)
+1
THANKS MUCH :icon_thumbsup:
I have the same wheels they are PM wheels. If you try to get matching rear rim the sprocket is different than stock just a fyi.
Do you think rvt silicone adhesive will hold frame plugs in ?
Thanks Dale just did the cct these photos were a great help. My bike sounds much better.
I have painted bolts right on the bike with a paint pen on my zx11 looks good.
I also would like to know the advantage or disadvantage of h4 opposed to h7 can someone shed some light.
Mine had different gearing when I bought it. I geared it back to stock for more usable power on the low end. If I remember right it was down two teeth in the rear.
Battery Tender Jr. and 2 battery’s
Buy another charger. :icon_duh:
