BIG BOY
Posts posted by BIG BOY
YOU WILL NEED MORE MEMORY!!!!!!
Can you add memory to that GPS?????
I like the Givi for summer time, spring riding. But when it gets cold, there's only one screen to run, and that's the one that Eric, EVLXX makes.
It is an aaaaaaaawesome screen.
Sometimes with just blipping the throttle it'll drop in.
I thought the Vista didn't work properly for some reason.
I thought the one of that style should be the NEP????
Garmin.
Etrex(spelling?)
They are supposed to be real comfy.
For the prices they have listed, i'll be buying some.
Sounds electrical???????
Maybe something in the wiring harness or a bad battery connection??
Run an MEZ4 on the rear with an M-1 upfront.
Check Ebay, there are many on there.
Also, check WalMart, they have some good priced ones. BUT if you don't get good software with the unit, the software itself is expensive.
I have the Penske, with the 1300 spring.
I'm a little under double of your weight, so my comments mean dick to you. Sorry, i just had to post here.
BUMP.
I wonder how the Conti Road Attack rear would work with a M-1 front???
What no pics yet.
SEND THE CHICKENS!!!!!!!!!!!!!!!!!!!!!!!!
3" dent........from the lenghth of his cock!!!!!!!!!!!!!!!!
buy a brand new used tank from Joe.
ABS PLASTIC CEMENT/GLUE.
I will be buying a set in a few weeks.
I would buy the kind that has links.
If you're talking about for the rear shock, you can use regular washers, but you can't go too big.
You better go back and post more pics. From all angles!!
Yeah, let's get some work done, now that you're back from the MegaXX.
Try it and let us know what you think of it.
Does any one have the part number for the tapered head bearings??
I thought i read a post a long time ago that thats' what the guys are using, and where did they order them from???
A sticker.
You CAN lower the bike.
You need to slide the fork tubes upward in the triple tree and get a lowering dog leg/bone for the rear.
HELP - Removing the rear wheel
22mm on clutch side and 27mm on throttle side.
