spEEdfrEEk Posted April 30, 2003 Posted April 30, 2003 Ok, there has been some mention of hitting plateaus on the low-carb diet recently. So I'd like to suggest a few things you can do to get over the hump. Lets assume you are using a typical Atkins approach.. Then: 1) Your first step is to include a "cheat meal" once a week on the weekend where you can pretty much eat anything you want. This works, primarily, by enhancing thyroid output which can slow under a strict Atkins regime. Lets suppose you've been doing the diet for a while and have lost a significant amount of weight (say 20 - 30 lbs) when you hit a plateau. There are 2 options at this point. 2) Include exercise. Many people say one should exercise to lose weight, but I've found that one can only exercise effectively after a good portion of the weight is lost. People who have lost 20-30 lbs. are ready to move to this step. 2a) Cardio stuff - the first step. A good way to start the process is via cardio activity. These include things like jogging, cycling, swimming, etc. The BEST way to use this to spur fat loss is to _avoid_ staying in the aerobic zone. IE: You want to do INTERVALS and not slow cardio. Slow cardio (heart rate < 120 BMP) is not as effective as interval training where heart rates can achieve 150 or higher. (I typically run up to 180 during interval cycling) Why? Because slow cardio does not deplete the body of blood glucose and stored glycogen (sugars). Doing intervals does! After interval training, your glucose is depleted and your body has no choice but running on fats afterwards. This state can last several hours, and this means you tap body fat stores harder (as ketone production will increase) To do intervals, you alternate between phases of high intensity and low intensity. IE: for running, start off by walking to warm up and then go immediately to 1.5 minutes of ALL OUT sprinting. At the end of 1.5 min. slow down and drop to a slow walking pace for the next 1.5 minutes. Repeat this 5 times and stop. This will give you 15 minutes of intervals and your heart rate will have shot through the roof 5 times. In fact, you will also have "felt the burn", which is an indication that you were running on and depleting stored sugar. If you don't feel like running, swimming or cycling, you can use other "impulse" type sports for a similar effect: basketball, raquetball, and tennis are good examples of interval type sports. 2b) Weightlifting - the best scheme. Lifting is the BEST form of anaerobic training and will increase your RMR (resting metabolic rate) by keeping your non-fat body mass and metabolism high while dieting. There is no better way to drop adipose than lift weights while using a cyclical ketogenic approach. In fact, I went from 217 (powerlifting weight) to 183 (motocross weight) in less than 1 year with this approach and actually IMPROVED my power and stamina. I have spent just as much time studying exercise kinesiology as I have bimedicine and nutrition, so if there are any lifting questions I can try to field them for you as well. It's beyond the scope of this discussion right now.. Lifting is the best choice for dropping fat while low-carb if you have a gym or gym membership. 3) "Fat fast" diet. If you are seriously stuck for a long time and all of the above has failed to get you restarted, then you should consider a "fat fast" scheme. The original"Fat Fast" was developed by Atkins for just this type of thing. (to try to circumvent the thyroid problem his diet induces). Basically for one week you restrict calories to 1000 kcal/day which is VERY low. The only foods you consume are extremely fatty and you need to maintain a ratio of 10% protein, 90% fat with 0 carbs at all times. It's tough but due to incredible ketone secretion you can restart fat loss and NOT lose muscle tissue while doing it. You can ONLY due this for ONE week - no more, or you'll risk retarding your RMR. Here's a link that describes the diet: http://atkinscenter.com/Archive/2001/12/21-237659.html 4) Thermogenic drugs. If all of the above fails to work for you, then you may consider the use of thermogenic drugs. I am going to hold off on describing this now because I don't want people to think it's an easy way out. I will explain it later if someone tries all of the above and still ends up stuck ;-) Alright guys, good luck!! :cool: TJ :cool: Quote
Hookman49 Posted April 30, 2003 Posted April 30, 2003 Thanks TJ. Really do apprecate all the help and effort you are putting into this. This diet and your help has been the best thing for me. Ken Quote
spEEdfrEEk Posted April 30, 2003 Author Posted April 30, 2003 No sweat bud! Glad I could help! :cool: TJ :cool: Thanks TJ. Really do apprecate all the help and effort you are putting into this. This diet and your help has been the best thing for me.Ken Quote
severdog Posted May 12, 2003 Posted May 12, 2003 TJ- I've been doing low-carb for a week, plus some exercise, but I tried interval training today after reading your above post....WOW. I feel the burn, dude. What's with these ketone strips that I read about? Are they something that I can buy in a drugstore and piss on? What do they tell you? Thanks for the advice.... Quote
spEEdfrEEk Posted May 12, 2003 Author Posted May 12, 2003 I tried interval training today after reading your above post....WOW. I feel the burn, dude. Yep, and the best thing is that afterwards your body hits your fat stores REALLY hard. (it has no choice, you've depleted blood glucose and muscle glycogen with the intervals). What's with these ketone strips that I read about? Are they something that I can buy in a drugstore and piss on? Yep, go to your local drugstore and ask for "ketostix" or "ketodiastix". The latter includes a glucose test if I am not mistaken. Just go for the lowest price. What do they tell you? How much excess ketone you are excreting in the urine stream. As long as you are showing trace, you are running on ketone metabolism (which indicates the best state for fat loss) Thanks for the advice.... No sweat bud! :cool: TJ :cool: Quote
