SLY DVL Posted May 10, 2010 Posted May 10, 2010 Guess this is a good a place as any to post this. Just thought I'd share my experience with my recently purchased Givi side luggage & Give top case & the SW Motech racking system. I like the Givi luggage, but Givi's racking system for the XX is hideous (IMO) with the bags removed. SW Motech makes a VERY nice product that looks much more appealing with the bags removed. And, the bonus is that the rack removes in about 30 seconds (both sides) leaving nothing but a few small latch points behind. Pricing for the SW Motech racking is comparable the the Givi rack. Installation was straight forward, with minimal tools required. They come with signal relocation brackets, but since I bobbed my signals there is enough clearance for the luggage without any mods. The following are pics with no rack, rack, rack & luggage etc. Quote
timomasalin Posted May 10, 2010 Posted May 10, 2010 Guess this is a good a place as any to post this. Just thought I'd share my experience with my recently purchased Givi side luggage & Give top case & the SW Motech racking system. I like the Givi luggage, but Givi's racking system for the XX is hideous (IMO) with the bags removed. SW Motech makes a VERY nice product that looks much more appealing with the bags removed. And, the bonus is that the rack removes in about 30 seconds (both sides) leaving nothing but a few small latch points behind. Pricing for the SW Motech racking is comparable the the Givi rack. Installation was straight forward, with minimal tools required. They come with signal relocation brackets, but since I bobbed my signals there is enough clearance for the luggage without any mods. The following are pics with no rack, rack, rack & luggage etc. Hi there! Thinking about going that route too as my Givi bracket keeps cracking for some reason, nothing to do with overloading or wheelies I'm sure...:-) Do the SW Motech brackets keep the bags more stable as well? Seems like the Givi brackets let them shimmy quite a bit and I imagine that may contribute to the stress cracks... Quote
SLY DVL Posted May 10, 2010 Author Posted May 10, 2010 I can't say for sure how much more stable they are compared to the Givi racking, since this is the first set of hard luggage I've had. It does seem however, to be VERY rigid when riding. I haven't loaded them to capacity yet though. The top case has a little more flex then I would like, but that's in the case itself, not the rack. The top rack is one solid piece so no welds to fatigue. There's one more bracket that I haven't installed yet that goes from side to side under the lic. plate for the side bags. Since I chopped my rear fender I need to mod. that bracket for final fitment. Twisted Throttle is the North American distributor for SW Motech out of Germany. Quote
OrganDonor Posted May 10, 2010 Posted May 10, 2010 I had the same set up on my Bird before selling them to Shotsfired. They are VERY stable. I didn't even attach the bottom rear cross bar to the license plate bracket (due to the fender eliminator.) It was just fine that way. Quote
Maverick1100 Posted September 22, 2010 Posted September 22, 2010 Hey, Nice system!! Has you had any problems with cracks on the tail section. I like the cleanest of it but seem like it would put a large load on 2 bolts very close to each other on the subframe. Cheers, emile Quote
SLY DVL Posted September 23, 2010 Author Posted September 23, 2010 Hey, Nice system!! Has you had any problems with cracks on the tail section. I like the cleanest of it but seem like it would put a large load on 2 bolts very close to each other on the subframe. Cheers, emile I loaded the top case & side bags up pretty good this summer on several trips and nothing shows any signs of wear or fatigue. At this point, I'm quite happy with the setup. Quote
