I could really use this mod.... :oops:
Does anyone know if there's a 3rd party product out there that can provide this feature?
http://www.cyclegadgets.com/Products/produ...uct.asp?Item=SM
.http://www.kisantech.com/kisanWeb3/frameSample.htm
When you use these things with a Honda, you will find that if the turn signal is turned off by the device, you'll need to cancel the signal manually before your turn signal will be able to function again. ALL Hondas do this as it has to do with the way that the turn signals are wired.
It's also too bad that Motorcycle Consumer News praised this product because it cost around $60 before the article was published a couple of years ago
