Canadian Bird Posted April 4, 2007 Posted April 4, 2007 Just a few thoughts on my upgrades. FW it's W, the Goodridge brake lines took five hours to install, bleeding etc. Ten lines and not an easy task, my tech told me. I just ordered the clutch line from Jaws to be installed along with the HID's I bought from John. The Penske rear shock is a vast improvement as are the 100 mm over front springs. I stuck with OEM fork oil weight. The remote had to be installed right by the centre stand grab rail b/c of how the resevoir exited the shock. Penske wasn't much help when called to ask for mounting instructions. I have to lift the seat to make any adjustments to the remote. Perhaps because of the Givi luggage set up that's not a bad location. I've ridden twice since the installs, due to "global warming" and tons of rain, WTF. I'm not a knee dragger, however I could be now, and the Bird sticks to the tarmack like glue, holds the line and rides very smooth, "soft", and comfy. I know the "set up" will have to be "fine tuned" but I'm very pleased with the ride now. I haven't had a long ride of twisties but the few I have been on instill much more confidence. The braided lines look brilliant but I just don't do "hard" braking so I'll have to wait till I get into the mountains, perhaps next month, to determine the effects of braided lines. I intalled a Pyramid Hugger but now, after reading a tread concerning tire rub, I'm a little worried b/c I buying a pair of Pirelli Diablo Stada's in a week or so and I'm wondering if they'll rub. I'll be installing new wheel bearing at the time of tire install. At 102 thousand kms it seems to be a good idea. New head bearings, battery, plugs, valve adj, all done as well. I only went with the HID low beams and will install a 100 W high beam as it apparently takes a moment to spool up and if I want to "blip" the highs, by time it's bright, the car is gone. I don't do much night riding so it should be more than adaquate. I suppose the next purchase will be a top line Radar Detector, maybe a GPS from Garmin. Perhaps an undertail but I don't like wimpy turn signals so I'm unsure. If I can figure out how to post jpegs, I will. I had to buy my wife a new car to appease my concious for dropping such a "boat load" of cash on my Bird. She's happy now. OK, that's my story and I'm sticking to it. Cheers, Canadian Bird Quote
MrBadExxample Posted April 4, 2007 Posted April 4, 2007 Good job, that sounds like a lot of work. I'm almost done with a very similar maintenance agenda on my 97 XX. A couple of questions: 1. Did you replace the steering head bearings with OEM or the aftermarket tapered ones. 2. Did your valves need adjusting. At 49K miles I had six exhasut values that were just a little too tight. Quote
XXTi Posted April 4, 2007 Posted April 4, 2007 Congrats on the mods. I've been running the same suspension set-up for a while now. I love it. Quote
Canadian Bird Posted April 4, 2007 Author Posted April 4, 2007 I replaced the stearing head with OEM bearings and although the valves were adjusted they didn't need shims. I will use OEM wheel bearings as well. I used Silkolene fork oil and Motul Semi Syn and a Motul "race" coolant. I used a Swiss dot 5.1 brake fluid. all this is probly "over kill" but it's my dime. Also EBC HH brake pads, all round. If I could find a turbo kit, I just might bite. Quote
