panote Posted January 30, 2007 Posted January 30, 2007 Something happen with my BB brake system. When I press pedal brake in first time,it's deep but it's will better in the second time.It's never happen when I use hand brake and pedal brake in the same time. And the secondary master cylinder is weak but it's still work with real caliper. How can I do ? :icon_think: Is it possible to bleeding some part of brake system ? Example: only brake pedal with center bleeding valve of front left / right caliper. or only brake pedal with rear center bleeding valve and rear upper bleeding valve. or only secondary master cylinder with rear upper bleeding valve. Thank you. Quote
bartonmd Posted January 30, 2007 Posted January 30, 2007 Something happen with my BB brake system. When I press pedal brake in first time,it's deep but it's will better in the second time.It's never happen when I use hand brake and pedal brake in the same time. And the secondary master cylinder is weak but it's still work with real caliper. How can I do ? :icon_think: Is it possible to bleeding some part of brake system ? Example: only brake pedal with center bleeding valve of front left / right caliper. or only brake pedal with rear center bleeding valve and rear upper bleeding valve. or only secondary master cylinder with rear upper bleeding valve. Thank you. Blead the entire brake system... Directions are in the manual... Mike Quote
